explanation about this program?solve error?
Hai, in first program what is the duty of do{} while(1); loop
and in 2nd program there is some error,
after I ring dosomething(); loop have to execute one time but here it is executing again and again,
I changed the arbitrary delay in various place in the program eventhough it is running again and again,
I need exactly if I ring one time it have to execute dosomething loop one time.
here I’m using6 and 7 th pins a Rx and Tx. I’m using Icomsat v.1.1 module there is no future to use 8th pin to select as Rx and Tx. Is it any problem for the serial read availability in arduino and sim900.
// Example 55.2
#include <SoftwareSerial.h>
SoftwareSerial SIM900(7, 8);
  SIM900.begin(19200);
  SIM900power();
  delay(20000);  // give time to log on to network.
void SIM900power()
// software equivalent of pressing the GSM shield "power" button
  digitalWrite(9, HIGH);
  digitalWrite(9, LOW);
  delay(5000);
void sendSMS()
  SIM900.print("AT+CMGF=1\r");                                                        // AT command to send SMS message
  delay(100);
  SIM900.println("AT + CMGS = \"+12128675309\"");                                     // recipient's mobile number, in international format
  delay(100);
  SIM900.println("Hello, world. This is a text message from an Arduino Uno.");        // message to send
  delay(100);
  SIM900.println((char)26);                       // End AT command with a ^Z, ASCII code 26
  delay(100);
  SIM900.println();
  delay(5000);                                     // give module time to send SMS
  SIM900power();                                   // turn off module
  sendSMS();
  do {} while (1);
char inchar; // Will hold the incoming character from the GSM shield
int onoff=0; // 0 = off, 1 = on
  Serial.begin(19200);
  // set up the digital pins to control
  pinMode(12, OUTPUT);
  pinMode(13, OUTPUT); // LEDs - off = red, on = green
  digitalWrite(12, HIGH);
  digitalWrite(13, LOW);
  // wake up the GSM shield
  SIM900power();
  SIM900.print("AT+CLIP=1\r"); // turn on caller ID notification
  delay(100);
void SIM900power()
  delay(7000);
void doSomething()
  if (onoff==0)
    onoff=1;
    Serial.println("D12 high D13 low");
    if (onoff==1)
      onoff=0;
      digitalWrite(12, LOW);
      digitalWrite(13, HIGH);
      Serial.println("D12 low D13 high");
  if(SIM900.available() >0)
    inchar=SIM900.read();
    if (inchar=='2')
      delay(10);
      if (inchar=='1')
        delay(10);
        if (inchar=='2')
          delay(10);
          if (inchar=='8')
            delay(10);
            if (inchar=='6')
              delay(10);
              if (inchar=='7')
                delay(10);
                if (inchar=='5')
                  delay(10);
                  if (inchar=='3')
                    delay(10);
                    if (inchar=='0')
                      delay(10);
                      if (inchar=='9')
                        Serial.println("do sometehing");
                        delay(10);
                        // now the number is matched, do something
                        doSomething();
                        // arbitrary delay so the function isn't called again on the same phone call
                        delay(60000);
Thank you
The code in the braces {} is executed again and again while the condition in the brackets () is true.
do {} while (1); will do nothing forever.
(set up a pin as a button input);
 do {
  somevar=digitalRead(buttonPin);
  (keep doing whatever you want done while a button is pressed);
 } while (somevar == HIGH);
