explanation code
hey,
I found a code on the internet that could read a MPU6050 the x-axis.
I have modified the code so a led would burn when there is an certain angle.
Now I don’t understand the code completely could someone please explain it?
#include <Wire.h>
#include<I2Cdev.h>
#include<MPU6050.h>
MPU6050 mpu;
int16_t ax, ay, az;
int16_t gx, gy, gz;
int led = 8;
void setup(){
 Serial.println("Initialize MPU");
 mpu.initialize();
void loop(){
 mpu.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
 ax = map(ax, -17000, 17000, -1500, 1500);
Serial.println(ax);
if(ax>300&& ax<400)
  analogWrite(led, 255);
else{
  digitalWrite(led, LOW);
#include <Wire.h>      //include the required libraries
#include<I2Cdev.h>
#include<MPU6050.h>
MPU6050 mpu;            //create an instance of the MPU6050 named mpu
int16_t ax, ay, az;     //declare 6 16 bit integer variables
int16_t gx, gy, gz;
int led = 8;            //give the led pin a name
  mpu.initialize();      //initialise the sensor
  mpu.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);  //read 6 values into 6 variables
  ax = map(ax, -17000, 17000, -1500, 1500);      change the range of the ax value from -17000/17000 to -1500/1500
  Serial.println(ax);
  if (ax > 300 && ax < 400)  //if the ax value is between 301 aand 399
    analogWrite(led, 255);    //turn on the LED (an odd way to do it, but it will work)
  else {
    digitalWrite(led, LOW);   //otherwise turn it off (an odd way to do it, but it will work)
thank you
