explanation some steps in code to measure frequency
Hey guys,
i have connect a wind sensor to arduino mega
wind sensor data sheet is
http://www.windandsun.co.uk/media/277060/NRG-40C-Anemometer-data-sheet.pdf
connection diagram of system has attached
the purpose of system is to record wind speed which be calculated as follow:
wind speed=o/p frequency*0.765+0.35
i surfed net and found this sketch and i made necessary modification
actually i don't understand some steps in sketch
please:don not replay with lmgtfy
long freq, tempo,wind_speed;
int pulsos;
boolean pulso;
pulso=HIGH;
pinMode(2,INPUT);
  // put your main code here, to run repeatedly:void loop() {
 [color=red] tempo = millis();
  if(digitalRead(2)==HIGH)
    if(pulso==HIGH)
pulsos = pulsos + 1;
pulso=LOW;
else{
pulso=HIGH;
  if(tempo%2000==0){
freq = pulsos;[/color]
wind_speed=freq*0.765+0.35;
Serial.print("wind speed=  ");
 Serial.print(wind_speed);
 Serial.print("   m/s");
 Serial.print("\t");
Serial.print("frequency= ");
 Serial.print("\t");
Serial.print(freq);
 Serial.print("\t");
Serial.println("Hz");
pulsos=0;
delay (5000);
i dont understand the function of this part
tempo = millis();
    if(pulso==HIGH)
pulso=LOW;
else{
pulso=HIGH;
  if(tempo%2000==0){
freq = pulsos
"tempo" should be "unsigned long"
"pulso" is a boolean - it should not have the value HIGH or LOW.
tempo = millis();   //save the current value od millis() (note comment from AWOL)
if (digitalRead(2) == HIGH) //if pin 2 is HIGH
  if (pulso == HIGH)  //if the pulso variable is HIGH (note comment from AWOL)
    pulsos = pulsos + 1;  //add 1 to pulsos
  pulso = LOW;  //change the state of pulso to LOW
  pulso = HIGH; //if pin 2 is not HIGH set pulso to HIGH
if (tempo % 2000 == 0)  //if the value of tempo is divisible by 2000 with no remainder
  freq = pulsos //copy the value of pulsos to the freq variable
The result of this section of code is to count HIGH pulses on pin 2 for 2000 milliseconds
AWOL:
It being a boolean variable means it can have either of 2 states in Boolean (or Boolian) mathematics according to it's inventor George B. There are no other states available then HIGH or LOW.
  if (HIGH==true) Serial.println("HIGH==true");
  Serial.println(HIGH,DEC);
  Serial.println(true,DEC);
  if (LOW==false) Serial.println("LOW==false");
  Serial.println(LOW,DEC);
  Serial.println(false,DEC);
void loop() {}
Deva_Rishi:
You'll have to do better than that - please show which of Bool's works mentions HIGH or LOW.
AWOL:
It is not about the name ! it is about the number of states.
Deva_Rishi:
Ah! But it is about the name.
An output pin could be HIGH, LOW or tristate.
AWOL:
and this tristate of yours you can write using digitalWrite() ?? and it is defined as ehm undefined isn't it ! and comparing it to either true or false ? hmm, tristate is an electronic state, not a logical state. Logical comparisons like (HIGH !=false) = true, (true | LOW) = true etc.
No, but it is a well defined state for an I/O pin. I suggest to look it up.
  tempo = millis();
    // 'pulso' is set to the opposite of the previous input value
    // so if both are HIGH the signal went from LOW to HIGH
    if (pulso == HIGH)
    pulso = LOW;  // Opposite of input
    pulso = HIGH;  // Opposite of input
  // Every two seconds...
    freq = pulsos;  // Record pulses per two seconds.  If two pulses per rev, this is revs per second
    wind_speed = freq * 0.765 + 0.35;  // Calculate wind speed
    Serial.print("\t");
    Serial.print("\t");
    Serial.print(freq);
    Serial.print("\t");
    pulsos = 0;  // Restart the pulse counter
    delay (5000);  // ?????
Deva_Rishi:
Well, yes. Yes I can.
I run my own modified Arduino core, and "digitalWrite (pin number, TRIS);" makes a lot of things like charlieplexing simpler and more flexible.
AWOL:
Oh well that is great, so you do pinMode(pin,INPUT);
How wonderful and how do you #define TRIS 2 ?? it is amazing, you change the pin 'mode'
No, that would be silly, and very wasteful.
Again, no. How terribly old-fashioned that would be.
Is there something wrong with your '?' key?
johnwasser:
  tempo = millis();
    if (pulso == HIGH)
    Serial.print("\t");
    Serial.print("\t");
    Serial.print(freq);
    Serial.print("\t");
thank you very much i understand from your replay that there is no need for this statement
delay(5000)
