I'm trying to do a Sketch > Export compiled Binary on Arduino IDE 1.8.5 but i only get 2 .hex files without the .bin file in the sketch folder. How do I generate the .bin file?
Output:
D:\Arduino\arduino-builder -dump-prefs -logger=machine -hardware D:\Arduino\hardware -hardware C:\Users\gio\AppData\Local\Arduino15\packages -tools D:\Arduino\tools-builder -tools D:\Arduino\hardware\tools\avr -tools C:\Users\gio\AppData\Local\Arduino15\packages -built-in-libraries D:\Arduino\libraries -libraries D:\Arduino\MY_SKETCHES\libraries -fqbn=arduino:avr:uno -ide-version=10805 -build-path C:\Users\gio\AppData\Local\Temp\arduino_build_665589 -warnings=default -build-cache C:\Users\gio\AppData\Local\Temp\arduino_cache_603271 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\gio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.avrdude.path=C:\Users\gio\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.arduinoOTA.path=D:\Arduino\hardware\tools\avr -verbose C:\Users\gio\Desktop\Blink\Blink.ino
D:\Arduino\arduino-builder -compile -logger=machine -hardware D:\Arduino\hardware -hardware C:\Users\gio\AppData\Local\Arduino15\packages -tools D:\Arduino\tools-builder -tools D:\Arduino\hardware\tools\avr -tools C:\Users\gio\AppData\Local\Arduino15\packages -built-in-libraries D:\Arduino\libraries -libraries D:\Arduino\MY_SKETCHES\libraries -fqbn=arduino:avr:uno -ide-version=10805 -build-path C:\Users\gio\AppData\Local\Temp\arduino_build_665589 -warnings=default -build-cache C:\Users\gio\AppData\Local\Temp\arduino_cache_603271 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\gio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.avrdude.path=C:\Users\gio\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.arduinoOTA.path=D:\Arduino\hardware\tools\avr -verbose C:\Users\gio\Desktop\Blink\Blink.ino
Using board 'uno' from platform in folder: D:\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: D:\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Users\gio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\Arduino\hardware\arduino\avr\cores\arduino" "-ID:\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\gio\AppData\Local\Temp\arduino_build_665589\sketch\Blink.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Users\gio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\Arduino\hardware\arduino\avr\cores\arduino" "-ID:\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\gio\AppData\Local\Temp\arduino_build_665589\sketch\Blink.ino.cpp" -o "C:\Users\gio\AppData\Local\Temp\arduino_build_665589\preproc\ctags_target_for_gcc_minus_e.cpp"
"D:\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\gio\AppData\Local\Temp\arduino_build_665589\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\gio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-ID:\Arduino\hardware\arduino\avr\cores\arduino" "-ID:\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\gio\AppData\Local\Temp\arduino_build_665589\sketch\Blink.ino.cpp" -o "C:\Users\gio\AppData\Local\Temp\arduino_build_665589\sketch\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core
Linking everything together...
"C:\Users\gio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-gcc" -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\gio\AppData\Local\Temp\arduino_build_665589/Blink.ino.elf" "C:\Users\gio\AppData\Local\Temp\arduino_build_665589\sketch\Blink.ino.cpp.o" "C:\Users\gio\AppData\Local\Temp\arduino_build_665589/..\arduino_cache_603271\core\core_arduino_avr_uno_fd040c28ca717db04400ddff4ecd4334.a" "-LC:\Users\gio\AppData\Local\Temp\arduino_build_665589" -lm
"C:\Users\gio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\gio\AppData\Local\Temp\arduino_build_665589/Blink.ino.elf" "C:\Users\gio\AppData\Local\Temp\arduino_build_665589/Blink.ino.eep"
"C:\Users\gio\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\gio\AppData\Local\Temp\arduino_build_665589/Blink.ino.elf" "C:\Users\gio\AppData\Local\Temp\arduino_build_665589/Blink.ino.hex"
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
