Hello there,
I'm just a begineer and I've searched the forums to no avail about this topic.
I'm trying to send DHT22 temperature and humidity data to excel using the standalone excel program, PLX-DAQ.
However I get the error message: " Error: Data < ASCII 10 or > ASCII > 200"
I'm guessing there is some data type incompatibility? (an integer is expected when it's sending a string to PLX-DAQ?, or vice versa).
What should I change in the code to make it compatible? Ideally, temperature and humidity will be in separate columns.
Additionally, each reading is of the following format from the serial monitor:
// Example testing sketch for various DHT humidity/temperature sensors
// Written by ladyada, public domain
#include "DHT.h"
#define DHTPIN 2 // what pin we're connected to
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22 (AM2302)
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
DHT dht(DHTPIN, DHTTYPE);
Serial.begin(38400);
Serial.println("DHT test");
dht.begin();
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity();
float t = dht.readTemperature();
// check if returns are valid, if they are NaN (not a number) then something went wrong!
if (isnan(t) || isnan(h)) {
Serial.println("Failed to read from DHT");
Serial.print("Humidity: ");
Serial.print(h);
Serial.print(" %\t");
Serial.print("Temperature: ");
Serial.print(t);
Serial.println(" *C");
Are the "Temperature " and "Humidity " strings going to be useful on every record of your excel file? If not, get rid of them. Send just h and t, possibly with a comma between them.
Definitely not. I was thinking about sending the H and T separated by a comma but I don't know how I should edit the code to do this (i've tried heaps),
#include "DHT.h"
Serial.println("LABEL,Time,Temperature (C), Humidity (%)");
dht.begin();
delay(60000);
Serial.print("DATA,TIME,"); Serial.print(t); Serial.print(","); Serial.println(h);
Hey.
I have been using the Arduino for 4 days now and have been able o successfully hook up an LCD and communicate with a DHT22. I would like to log data into an .xls . I have the PLX-DAQ and am not sure how to use its logging functionality. Can I have any links to a setup tut?
