Extended ASCII in Header File
Hi everyone!
I'm having problem with strings in Header Files. I split my project into multiple Header Files in the same folder of the Sketch (with one .cpp files in sketch folder, I have problems), those header files are just part of the code included in the .ino, and I would like to keep it separated.
As I'm using Extended ASCII characters in the strings, for example:
Configurações
I have this line in preferences.txt of Arduino:
preproc.substitute_unicode=false
If I use this string in the .ino file, I get no problem at printing and drawing, as each Extented ASCII are correct (one byte).
BUT using it in header files, I get this printing it:
Configurações
Because, I think, the Extended ASCII are being replaced by UNICODE (two bytes rather than one of ASCII).
Is there a way to solve it, to make it stop replacing by UNICODE?
Sincerely, User
Which editor did you last use to change the header files?
I've used Notepad++.
That is very likely the culprit. Notepad++ is probably treating the files as UTF-8 instead of "no encoding" / "raw".
What is receiving / interpreting the strings? An LCD display?
Printing in a TFT display shows the same problem:
Configurações
rather than:
Configurações
I will try other codifications, like ANSI.
giova014: Printing in a TFT display shows the same problem:
Configurações
rather than:
Configurações
The problem is that ASCII (sometimes incorrectly called "ANSI") does not have those "extended" characters. Some 8-bit character sets, such as ISO8859-1 and Windows-1252, do have those characters. Try using one of those encodings if they're available.
I've tried all the codifications, but no positive result.
My solution for now is writing:
"Configurações"
as:
"Configura\xE7\xF5es"
or even:
{'C','o','n','f','i','g','u','r','a',231,245,'e','s'}
In the last case I think it's suitable using with a macro (considerating memory for the '\0').
Thanks for all the help!
