Hi. So I was wondering about adding a few custom commands to the WiFi NINA firmware for my Nano RP2040 Connect. To start off, I just wanted to add a simple "ping" command (with no parameters) which would reply with a 4-character long string "pong".
I cloned the arduino/nina-fw repository and set up my building environment according to the README in the repo. I am able to successfully compile the firmware.
Since the is no documentation on adding custom commands. I just guessed the following:
main/CommandHandler.cpp:
I added my command handler to the commandHandlers array:
const CommandHandlerType commandHandlers[] = {
stupidPing, //0x80
Above this array, I added the function which handles the command:
int stupidPing(const uint8_t command[], uint8_t response[])
//Dumb ping command - responds with "pong" (char[4])
const char response_msg[5] = "pong";
uint8_t msgLen = strlen(response_msg);
response[2] = 1; // number of parameters
response[3] = msgLen; // parameter 1 length
memcpy(&response[4], response_msg, msgLen);
return (5 + msgLen);
I compiled and flashed this modified firmware to the ublox module.
Of course, the WiFiNINA library also had to be modified, which I did like this:
WiFiNINA/src/utility/wifi_spi.h:
enum {
STUPID_PING = 0x80,
WiFiNINA/src/utility/wifi_drv.cpp:
bool WiFiDrv::stupidPing(uint8_t* rcvd){
WAIT_FOR_SLAVE_SELECT();
// Send Command
SpiDrv::sendCmd(STUPID_PING, PARAM_NUMS_1);
uint8_t _dummy = DUMMY_DATA;
SpiDrv::sendParam(&_dummy, 1, LAST_PARAM);
// pad to multiple of 4
SpiDrv::readChar();
SpiDrv::readChar();
SpiDrv::spiSlaveDeselect();
//Wait the reply elaboration
SpiDrv::waitForSlaveReady();
SpiDrv::spiSlaveSelect();
char msg[5];
memset(msg, 0x00, sizeof(msg));
// Wait for reply
uint8_t _dataLen = 0;
SpiDrv::waitResponseCmd(STUPID_PING, PARAM_NUMS_1, (uint8_t*)msg, &_dataLen);
*rcvd = _dataLen;
return strcmp(msg, "pong") == 0;
(I also added this command to the WiFiDrv class in wifi_drv.h)
Now I used the following sketch to test this command:
#include <WiFiNINA.h>
while(!Serial);
Serial.println("Testing STUPID_PING command!");
uint8_t rcvd = 0;
bool x = WiFiDrv::stupidPing(&rcvd);
if(x){
Serial.println("Test successfull!");
Serial.println("Test failed");
Serial.print("Bytes received: ");
Serial.println(rcvd);
I keep getting "Test failed" and 0 bytes received on the serial monitor and it also looks like SpiDrv::waitResponseCmd() is failing (returns 0).
Could someone please help me?
