buttimer:
As I said in my original posting, I "inherited" this code (see see Detect Lockups | Articles | MegunoLink ) and it worked fine until I added the interrupt counter. It seemed such a simple addition !! However, I will do further experiments ! Can I ask what WDT code (if any) you have in your ISR where the counter has NOT been satisfied - I suspect that is where my problem resides ...... !
Ok, I see how the code is mostly "inherited", not sure how I missed that in your OP.
Anyway, it was bothering me a little, especially the double timeout bit, so I've taken another look at it.
The issue is simple: The WDT has multiple operating modes
- stopped
- interrupt mode
- system reset mode
- interrupt and system reset mode
- system reset mode
You are using the red one, which means that the first timeout causes an interrupt. You do your counter thing but unfortunately you don't reset the interrupt handling, so the next timeout causes a reset.
And, as I mentioned before, the use of the naked ISR is ok if the only action is going to be to reset the device, but since you are wanting to continue execution in some cases, you need to protect the pre-ISR state.
I've attached a modified ApplicationMonitor.cpp that might do what you want, with a few caveats:
- it was tested on an Arduino Micro with the demo code from the website, the code may be MCU specific, YMMV
- it's not thoroughly tested, no warranty, use at your own risk
- for it to work in your use-case, the WDIE bit of the WDTCSR register has to be set inside of the ISR - this could potentially compromise the reset handling in some (possibly rare circumstances) - see the datasheet for more details
The main change is the ISR is now written in inline ASM, I'll post it here inline in case anyone else wants to pick through it:
// How many watchdog interrupt repeats to perform.
const byte c_iIsrMaxCount = 5;
Function called when the watchdog interrupt fires. The function is naked so that
we don't get program stated pushed onto the stack. Consequently the top two
values on the stack will be the program counter when the interrupt fired. We're
going to save that in the eeprom then let the second watchdog event reset the
micro. We never return from this function.
uint8_t *upStack __attribute__((used));
extern "C" {
void appMon_asm_gate(void) __attribute__((used));
void appMon_asm_gate(void){
ApplicationMonitor.WatchdogInterruptHandler(upStack);
// Global Interrupt counter
volatile byte g_iInterruptCounter = 0;
ISR(WDT_vect, ISR_NAKED)
__asm__ __volatile__ (
"; save SP \n\t"
"push r24 \n\t"
"push r25 \n\t"
"in r24, __SP_L__ \n\t"
"in r25, __SP_H__ \n\t"
"; save SREG \n\t"
"push r16 \n\t"
"in r16, __SREG__ \n\t"
"push r16 \n\t"
"; handle ISR repeats \n\t"
"lds r16, g_iInterruptCounter \n\t"
"cpi r16, %[IsrMaxCount] \n\t"
"brlo no_reset \n\t"
"; store the stack location of pre-ISR PC \n\t"
"adiw r24, 0x03 \n\t"
"sts upStack+1, r25 \n\t"
"sts upStack, r24 \n\t"
"; clear zero reg and invoke gate \n\t"
"clr r1 \n\t"
"call appMon_asm_gate ; reset occurs here \n\t"
"no_reset:\n\t"
"; increment counter \n\t"
"inc r16 \n\t"
"sts g_iInterruptCounter, r16 \n\t"
"; reset watchdog interrupt, some DANGER involved, see WDIE docs \n\t"
"lds r16, 0x60 ; WDTCSR \n\t"
"sbr r16, 0x40 ; set WDIE bit \n\t"
"sts 0x60, r16 ; WDTCSR \n\t"
"; restore SREG \n\t"
"pop r16 \n\t"
"out __SREG__,r16 \n\t"
"pop r16 \n\t"
"; restore regs \n\t"
"pop r25 \n\t"
"pop r24 \n\t"
"reti \n\t"
:: [IsrMaxCount] "M" (c_iIsrMaxCount)
HTH.
ApplicationMonitor.cpp (7.19 KB)
