'extern' and later 'static' error
I have used the below code a while back (having modified it from Łukasz Marcin Podkalicki's original code). Since then I have reconfigured my computer and so my Arduino IDE settings may have changed.
I tried to recompile this code today but got the following error
exit status 1
'void tone(uint8_t, uint8_t)' was declared 'extern' and later 'static' [-fpermissive]
I have tried research online but am still not sure what this means or how to fix it.
   Copyright (c) 2016, Łukasz Marcin Podkalicki <lpodkalicki@gmail.com>
   ATtiny13/007
   Simple tone generator.
   Settings:
    FUSE_L=0x6A
    FUSE_H=0xFF
    F_CPU=1200000
#include <avr/io.h>
#include <avr/interrupt.h>
#include <avr/pgmspace.h>
#include <util/delay.h>
#define  BUZZER_PIN  0
#define  SENSOR_PIN    1
#define N_1 (_BV(CS00))
#define N_8 (_BV(CS01))
#define N_64  (_BV(CS01)|_BV(CS00))
#define N_256 (_BV(CS02))
#define N_1024  (_BV(CS02)|_BV(CS00))
bool TUNE_PLAYED;
typedef struct s_note {
  uint8_t OCRxn; // 0..255
  uint8_t N;
} note_t;
typedef struct s_octave {
  note_t note_C;
  note_t note_CS;
  note_t note_D;
  note_t note_DS;
  note_t note_E;
  note_t note_F;
  note_t note_FS;
  note_t note_G;
  note_t note_GS;
  note_t note_A;
  note_t note_AS;
  note_t note_B;
} octave_t;
  All calculations below are prepared for ATtiny13 default clock source (1.2MHz)
  F = F_CPU / (2 * N * (1 + OCRnx)), where:
  - F is a calculated PWM frequency
  - F_CPU is a clock source (1.2MHz)
  - the N variable represents the prescaler factor (1, 8, 64, 256, or 1024).
PROGMEM const octave_t octaves[8] = {
  { // octave 0
    .note_C = {142, N_256}, // 16.35 Hz
    .note_CS = {134, N_256}, // 17.32 Hz
    .note_D = {127, N_256}, // 18.35 Hz
    .note_DS = {120, N_256}, // 19.45 Hz
    .note_E = {113, N_256}, // 20.60 Hz
    .note_F = {106, N_256}, // 21.83 Hz
    .note_FS = {100, N_256}, // 23.12 Hz
    .note_G = {95, N_256}, // 24.50 Hz
    .note_GS = {89, N_256}, // 25.96 Hz
    .note_A = {84, N_256}, // 27.50 Hz
    .note_AS = {79, N_256}, // 29.14 Hz
    .note_B = {75, N_256} // 30.87 Hz
  { // octave 1
    .note_C = {71, N_256}, // 32.70 Hz
    .note_CS = {67, N_256}, // 34.65 Hz
    .note_D = {63, N_256}, // 36.71 Hz
    .note_DS = {59, N_256}, // 38.89 Hz
    .note_E = {56, N_256}, // 41.20 Hz
    .note_F = {53, N_256}, // 43.65 Hz
    .note_FS = {50, N_256}, // 46.25 Hz
    .note_G = {47, N_256}, // 49.00 Hz
    .note_GS = {44, N_256}, // 51.91 Hz
    .note_A = {42, N_256}, // 55.00 Hz
    .note_AS = {39, N_256}, // 58.27 Hz
    .note_B = {37, N_256} // 61.74 Hz
  { // octave 2
    .note_C = {142, N_64}, // 65.41 Hz
    .note_CS = {134, N_64}, // 69.30 Hz
    .note_D = {127, N_64}, // 73.42 Hz
    .note_DS = {120, N_64}, // 77.78 Hz
    .note_E = {113, N_64}, // 82.41 Hz
    .note_F = {106, N_64}, // 87.31 Hz
    .note_FS = {100, N_64}, // 92.50 Hz
    .note_G = {95, N_64}, // 98.00 Hz
    .note_GS = {89, N_64}, // 103.83 Hz
    .note_A = {84, N_64}, // 110.00 Hz
    .note_AS = {79, N_64}, // 116.54 Hz
    .note_B = {75, N_64} // 123.47 Hz
  { // octave 3
    .note_C = {71, N_64}, // 130.81 Hz
    .note_CS = {67, N_64}, // 138.59 Hz
    .note_D = {63, N_64}, // 146.83 Hz
    .note_DS = {59, N_64}, // 155.56 Hz
    .note_E = {56, N_64}, // 164.81 Hz
    .note_F = {53, N_64}, // 174.61 Hz
    .note_FS = {50, N_64}, // 185.00 Hz
    .note_G = {47, N_64}, // 196.00 Hz
    .note_GS = {44, N_64}, // 207.65 Hz
    .note_A = {42, N_64}, // 220.00 Hz
    .note_AS = {39, N_64}, // 233.08 Hz
    .note_B = {37, N_64} // 246.94 Hz
  { // octave 4
    .note_C = {35, N_64}, // 261.63 Hz
    .note_CS = {33, N_64}, // 277.18 Hz
    .note_D = {31, N_64}, // 293.66 Hz
    .note_DS = {29, N_64}, // 311.13 Hz
    .note_E = {27, N_64}, // 329.63 Hz
    .note_F = {26, N_64}, // 349.23 Hz
    .note_FS = {24, N_64}, // 369.99 Hz
    .note_G = {23, N_64}, // 392.00 Hz
    .note_GS = {22, N_64}, // 415.30 Hz
    .note_A = {20, N_64}, // 440.00 Hz
    .note_AS = {19, N_64}, // 466.16 Hz
    .note_B = {18, N_64} // 493.88 Hz
  { // octave 5
    .note_C = {142, N_8}, // 523.25 Hz
    .note_CS = {134, N_8}, // 554.37 Hz
    .note_D = {127, N_8}, // 587.33 Hz
    .note_DS = {120, N_8}, // 622.25 Hz
    .note_E = {113, N_8}, // 659.25 Hz
    .note_F = {106, N_8}, // 349.23 Hz
    .note_FS = {100, N_8}, // 369.99 Hz
    .note_G = {95, N_8}, // 392.00 Hz
    .note_GS = {89, N_8}, // 415.30 Hz
    .note_A = {84, N_8}, // 440.00 Hz
    .note_AS = {79, N_8}, // 466.16 Hz
    .note_B = {75, N_8} // 493.88 Hz
  { // octave 6
    .note_C = {71, N_8},  // 1  1046.50 Hz
    .note_CS = {67, N_8}, // 2  1108.73 Hz
    .note_D = {63, N_8},  // 3  1174.66 Hz
    .note_DS = {59, N_8}, // 4  1244.51 Hz
    .note_E = {56, N_8},  // 5  1318.51 Hz
    .note_F = {53, N_8},  // 6  1396.91 Hz
    .note_FS = {50, N_8}, // 7  1479.98 Hz
    .note_G = {47, N_8},  // 8  1567.98 Hz
    .note_GS = {44, N_8}, // 9  1661.22 Hz
    .note_A = {42, N_8},  // 10 1760.00 Hz
    .note_AS = {39, N_8}, // 11 1864.66 Hz
    .note_B = {37, N_8}   // 12 1975.53 Hz
  { // octave 7
    .note_C = {35, N_8}, // 2093.00 Hz
    .note_CS = {33, N_8}, // 2217.46 Hz
    .note_D = {31, N_8}, // 2349.32 Hz
    .note_DS = {29, N_8}, // 2489.02 Hz
    .note_E = {27, N_8}, // 2637.02 Hz
    .note_F = {26, N_8}, // 2793.83 Hz
    .note_FS = {24, N_8}, // 2959.96 Hz
    .note_G = {23, N_8}, // 3135.96 Hz
    .note_GS = {22, N_8}, // 3322.44 Hz
    .note_A = {20, N_8}, // 3520.00 Hz
    .note_AS = {19, N_8}, // 3729.31 Hz
    .note_B = {18, N_8} // 3951.07 Hz
static void
tone(uint8_t octave, uint8_t note)
  uint32_t ret;
  note_t *val;
  ret = pgm_read_word_near((uint8_t *)&octaves + sizeof(octave_t) * octave + sizeof(note_t) * note);
  val = (note_t *)&ret;
  TCCR0B = (TCCR0B & ~((1 << CS02) | (1 << CS01) | (1 << CS00))) | val->N;
  OCR0A = val->OCRxn - 1; // set the OCRnx
  _delay_ms(100);
  stop();
  _delay_ms(50);
static void
stop(void)
  TCCR0B &= ~((1 << CS02) | (1 << CS01) | (1 << CS00)); // stop the timer
static void
tune(void)
  tone(3, 9); // A
  tone(3, 8); // G#
  tone(3, 7); // G
  tone(3, 6); // Gb
  tone(3, 5); // F
  tone(3, 4); // E
  tone(3, 3); // D#
  tone(3, 2); // D
  tone(3, 0); // C
  tone(3, 2); // D
  tone(3, 4); // E
  tone(3, 5); // F
  tone(3, 4); // E
  tone(3, 4); // E
  tone(3, 4); // E
  tone(3, 4); // E
  stop();
int
main(void)
  /* setup */
  DDRB = 0b00000001; // set BUZZER pin as OUTPUT
  PORTB = 0b00000000; // set all pins to LOW
  TCCR0A |= (1 << WGM01); // set timer mode to Fast PWM
  TCCR0A |= (1 << COM0A0); // connect PWM pin to Channel A of Timer0
  pinMode(SENSOR_PIN, INPUT_PULLUP);
  TUNE_PLAYED = false;
  /* loop */
  while (1) {
    if (digitalRead(SENSOR_PIN) == HIGH) {
      if (!TUNE_PLAYED) {
        tune();
        TUNE_PLAYED = true;
    if (digitalRead(SENSOR_PIN) == LOW) {
that is not the complete error. There is a handy button in the IDE, in the output window, where you can copy EVERYTHING to use as a post. Do that.
The log was too large to paste here so I have included it as an attachment.
I have also added the verbose log.
error.log.txt (11.8 KB)
error-verbose.log.txt (16.8 KB)
By far, the easiest path forward is to change the name of your tone function to something else.
static void
The cause appears to be that 'tone' is being re-defined i suspect the sketch may be written for use with a different core (that does not have tone(int, int); as a built-in function.)
I would anyway not try to create notes this way, but that is a different matter.
Unless you intend to play 2 tomes simultaneously, the inaccuracy of using PWM is such that it will be disturbing to the ear and using a simple delayMicroseconds() method will get you better end results.
I changed tone to mytone but still got errors (see attached)
I will see if I can find the right core
error-verbose.log-2.txt (6.78 KB)
Changed the board to DIY ATtiny and it worked.. still gave the warnings but worked :slight_smile: Thanks
