Hello,
I want to set up the timer interrupt 1 for external clock input on the Due.How do I do it? I have some code for the timer but it is set to internal clock4. I need to give it an external clock.
void startTimer(Tc *tc, uint32_t channel, IRQn_Type irq, uint32_t frequency) {
pmc_set_writeprotect(false);
pmc_enable_periph_clk((uint32_t)irq);
TC_Configure(tc, channel, TC_CMR_WAVE | TC_CMR_WAVSEL_UP_RC | TC_CMR_TCCLKS_TIMER_CLOCK4);
uint32_t rc = VARIANT_MCK/128/frequency; //128 because we selected TIMER_CLOCK4 above
TC_SetRA(tc, channel, rc/2); //50% high, 50% low
TC_SetRC(tc, channel, rc);
TC_Start(tc, channel);
tc->TC_CHANNEL[channel].TC_IER=TC_IER_CPCS;
tc->TC_CHANNEL[channel].TC_IDR=~TC_IER_CPCS;
NVIC_EnableIRQ(irq);
I need the Due code to do the following in the atmega328 code below.
// setup timer1 for codec clock division
TCCR1A = 0x00; // set to CTC mode
TCCR1B = 0x0f; // set to CTC mode, external clock
TCCR1C = 0x00; // not used
TCNT1H = 0x00; // clear the counter
TCNT1H = 0x00;
#if SAMPLE_RATE == 88
OCR1AH = 0x00; // set the counter top
OCR1AL = 0x3f;
#elif (SAMPLE_RATE == 44) || (SAMPLE_RATE == 22)
OCR1AL = 0x7f;
#elif SAMPLE_RATE == 8
OCR1AH = 0x02; // set the counter top
OCR1AL = 0xbf;
#elif SAMPLE_RATE == 2
OCR1AH = 0x04; // set the counter top
OCR1AL = 0x7f;
#endif
TIMSK1 = 0x02; // turn on compare match interrupt
// turn off all enabled interrupts (delay and wire)
TIMSK0 = 0x00;
TWCR = 0x00;
sei(); // turn on interrupts
