External Clock & Interrupts
Hi everyone,
I was wondering if I can check on something with you guys in relation to another project I'm tinkering with.
The device I'll be working with communicates using a 2.56MHz clock via a bi-directional data line.
Before I started, I wanted to play around with my board (Mini Pro) and see how it responded to the external clock signals.
I put together the following simple code in the hopes that the output (pin 10) would pretty much follow the input (pin 2).
pinMode(2, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(2), test, RISING);
void loop(){
void test(){
PINB = _BV(2);
Unfortunately, if you look at the screenshot where I've got the external clock on Channel 0 (top signal), the Arduino lagging behind and outputting a lot slower (around 190kHz).
I'm not an expert on the Arduino hardware so if anyone can help explain why this is, I would appreciate it.
Cheers,
Armen
  1. Yes that looks about right!
  2. Whats the device? 2.56MHz is an odd freq!
  3. What is it you expect the arduino to do with the signal?
Mark
Hi Mark, thanks for your message.
It's an old board from an E&M rack (ham radio/comms). I don't have it hooked up yet though. It's just the Arduino and an external clock source at the moment,
I'm not sure what you mean about it looking right though.
My expectation was that at each rise on the clock signal, the output should flip. At least that's what I think the code should do.
I don't understand why the Arduino is lagging by 14 cycles?
Because of the time it takes to deal with the interrupt. You are feeding a signal which is not too far from the processor's clock signal, and there is not enough time to catch every cycle of your signal.
Interrupt servicing involves preserving the state of the machine before the ISR code is run and then restoring it after it is finished.
Thank's Grumpy_Mike, that makes perfect sense.
Now I just need to figure out what I should do next... use different coding strategy or use a board with a faster processor.
Cheers,
Armen
First there is no "lag" the processor is just losing all the interrupts it can't deal with.
Second just WTF are you trying to do!
Mark
If you know the frequency then why are you still monitoring it and trying mimic it at same time?
holmes4:
Well that is why I said it's lagging, because it's not fast enough to deal with all the clock rises especially when the interrupt stops every other process. Grumpy_Mike's explanation was very clear.
holmes4:
When people ask me for help I try to be as polite as possible and would appreciate the same.
Slumpert:
Slumpert, the reason for the code above was to gauge the ability of my Mini Pro to be able to do what I want it to do with the program I am planning on putting together.
The device is an analogue to PCM converter I bought at an auction and interfaces nicely with some radio gear I have laying around.
The way it receives and transmits data is simple, via a 20-bit transaction at clock speed:
  1. A 10 bit string must first be sent to it which contains the data (start bit, data, etc).
  2. It will then respond with 10 bits of its own.
That's it. I think it's somewhat similar to the SPI function but could be wrong.
Anyway, this is a long-term project I want to work on, it's been a goal of mine for a while. I look at the pile of wires and the breadboard in my cupboard sometimes and every now and then I take it all out, hook it up to my computer and play around with it.
All I am trying to do now is figure out if my Arduino hardware will be sufficient, or if I need to look at a Teensy or even an FPGA (which I have no experience with).
From what Grumpy_Mike has explained, it might be best to look at another platform.
