External crystal for Attiny85
I would like to employ an external 20MHz crystal for Attiny85.
I see that the crystal must be attached to pins 2 and 3. And datasheet gives us recommended values for the capacitors. OK.
However, the question is, pins 2 and 3, cannot be used for inputs/outputs if an external crystal is present?
Thanks in advance
Correct.
(deleted)
spycatcher2k:
Hi - You can use the pins as I/O if you do not use a crystal, You can set the chip to use an internal 8Mhz (or 1Mhz with divide by 8 set). OR run the chip at upto 20Mhz with the crystal & caps. Having built over 100 projects with 45/85 chips, I have not used a crystal setup yet (other than on my programming board, just incase I set the fuses to use external clock).
Yes... however in my case I need a lot of power because I have to make 3 FFT from 3 microphones continuously... so 20MHz better than 8. But I do not have pins enough if I use a external crystal.
I need 3 analogs input for the mics and one pin for sending the information to another Arduino.
ProfePaco:
The AtTiny85 has a PLL circuit that can be used as a system clock source for 16MHz (64MHz / 4) operation. All you need is to program the approriate clock select fuse.
BenF:
ProfePaco:
Wow, thanks, that is mighty good to know.
V-USB - A Firmware-Only USB Driver for Atmel AVR Microcontrollers here is an example of the attiny45 (but could be used on attiny85) used with its internal oscillator at 16.5Mhz if you download the source code youll see how that its done
hope this helps
Thanks for the feedback!
ProfePaco:
spycatcher2k:
If I am not mistaken, FFT on a single channel it a quite a stretch on a ATmega328 (Arduino) at 20MHz, so 3 channel FFT with tiny45/85, is it realistic ?
old topic, but related question:
If I want to use the SoftwareSerial library with an Attiny85 I would use an external 20Mhz crystal?
Or tune the internal osccilator
http://forum.arduino.cc/index.php?PHPSESSID=02dq48s3merutqi5fnfgdll743&topic=183180.msg1357164#msg1357164
20mhz (actually 30mhz) is no problem for t85 using pll and oscal reg. however w/o a hardware multiplier fft would be hard.
