I have an Arduino Pro Mini 5v, 16 mhz and it is connected to a digital switch on pin 2. This switch is used to wake the Arduino from sleep using a external digital interrupt. I also have a DHT11 temperature sensor connected to pin 9. What I want to achieve is the when the Arduino is awake for 5 seconds and also when the switch on pin 2 is HIGH, I want to read the temperature sensor and return the temperature. I am using the DHT11 library by Tillart and when I do this, it returns a TIME_OUT error. The only possible explanation I have for this is that somehow the voltage is changed when both the DHT11 and the switch on pin 2 is being read together? Any pointers to a solution will be greatly appreciated. I also forgot to to mention that I am using the LowPower library by RocketScream to put the Arduino to sleep. The library can be found here: https://github.com/rocketscream/Low-Power. I have pasted my code with this post as well. Thank you.
#include <LowPower.h>
#include <dht.h>
int pin2 = 2;
dht DHT;
#define DHT11_PIN 9
void pin2interrupt(void)
// Function called when awoken from sleep
// Detach interrupt to stop it from continuosly firing when in normal mode
void enterSleep(void)
attachInterrupt(digitalPinToInterrupt(2), pin2interrupt, RISING);
Serial.println("Sleeping");
delay(100);
LowPower.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF);
Serial.println("Awake!");
pinMode(pin2, INPUT);
int loop_iterations = 0;
loop_iterations++;
Serial.println("Awake in the loop!");
Serial.println(loop_iterations);
if (digitalRead(pin2) == LOW && loop_iterations >= 5)
Serial.println("No child detected, so going to sleep!");
delay(200);
enterSleep();
else if (loop_iterations >= 10)
delay(2000);
int chk = DHT.read11(DHT11_PIN);
delay(2000);
Serial.print("DHT11, \t");
switch (chk)
case DHTLIB_OK:
Serial.print("OK,\t");
case DHTLIB_ERROR_CHECKSUM:
Serial.print("Checksum error,\t");
case DHTLIB_ERROR_TIMEOUT:
Serial.print("Time out error,\t");
default:
Serial.print("Unknown error,\t");
// DISPLAY DATA
Serial.println(DHT.temperature, 1);
