External Eeprom - Information
Good Afternoon,
for my project i was thinking to implement external eeprom instead of arduino eeprom because I have at disposition 1.000.000 of write cycle instead of 100.000.
then before to write a post (how ever I’ve tried to look inside google) and I’ve found this: topic
http://www.hobbytronics.co.uk/arduino-external-eeprom
#include <Wire.h>
#define disk1 0x50    //Address of 24LC256 eeprom chip
void setup(void)
  Wire.begin();
  unsigned int address = 0;
  writeEEPROM(disk1, address, 123);  // eeprom is at the 0x50, add of memory 0 and data 123
  Serial.print(readEEPROM(disk1, address), DEC);
void loop(){}
void writeEEPROM(int deviceaddress, unsigned int eeaddress, byte data )
  Wire.beginTransmission(deviceaddress);
  Wire.write((int)(eeaddress >> 8));   // MSB
  Wire.write((int)(eeaddress & 0xFF)); // LSB
  Wire.write(data);
  Wire.endTransmission();
  delay(5);
byte readEEPROM(int deviceaddress, unsigned int eeaddress )
  byte rdata = 0xFF;
  Wire.requestFrom(deviceaddress,1);
  if (Wire.available()) rdata = Wire.read();
  return rdata;
This line of code what are means ?:
  Wire.write((int)(eeaddress >> 8));   // What are means ?
  Wire.write((int)(eeaddress & 0xFF)); // What are means ?
and this
  Wire.requestFrom(deviceaddress,1);  //What are means ?
Looking the example is not more easy like write and read Arduino Eeprom … so my question is:
Is there some library that I can use in order to use “external eeprom” easily as “arduino eeprom” ?
Thanks 10000 for support,
Gnux
External EEPROM is typically accessed via an SPI or I2C interface. Your example appears to be using I2C interface: #include <Wire.h>
Both send out addresses and data as 8-bit numbers (a byte).
This a 16 bit address
This breaks it up into 2 bytes and sends it out:
Wire.write((int)(eeaddress >> 8 )); // If the address was 0x1234, this shifts the 12 over 8 bit positions and sends it out
Wire.write((int)(eeaddress & 0xFF)); // This masks off the 12, so that only 34 is left and sends it out.
Another way to perform this would be:
Wire.write((int)(highByte(eeaddress));
Wire.write((int)(lowByte(eeaddress));
This is setting up the address that will be read from.
This tells the device to send 1 byte. deviceaddress will be the EEPROMs I2C bus address; typically the lowest bit of the address will be 0 or 1 to tell the device a read or write is occurring;
Wire.write(data); will send data to the device
Wire.read(); will read the data the device sends
this link will help you understand what's going on here;
http://www.cprogramming.com/tutorial/bitwise_operators.html
That link only helps for the >> 8 question. The main question was understanding I2C operation.
