Members
I am trying to write zero to the entire page but get some numbers in between when its read back.
/*eeprom_LongStrings
* write across pages
http://www.hobbytronics.co.uk/eeprom-page-write
DUE + one 24LC256
#include <Wire.h> //use SCL & SDA
extern TwoWire Wire1; //use SCL1 & SDA1
#define disk1 0x50 //Address of 24LC256 eeprom chip
#define WRITE_CNT 285 //how many writes
unsigned char rdata[32];
void setup(void)
Wire.begin();
Wire1.begin(); // join i2c bus
unsigned int i;
// define large string of data to be written
char str_data[] = {"0"};
// Work out length of data
char str_len = 0;
do {
str_len++;
} while (str_data[str_len]);
// Write out data several times consecutively starting at address 0
for (i = 0; i < WRITE_CNT; i++) writeEEPROM(disk1, i * str_len, str_data);
//write once only
//writeEEPROM(disk1, i * str_len, str_data);
// read back the data 28 bytes at a time
// reading data doesn't suffer from the page boundary rules
//Serial.println("DATA READ");
for (i = 0; i < 10; i++) {
readEEPROM(disk1, (i * 28), rdata, 28);
Serial.write(rdata, 28);
Serial.print(*rdata);
void writeEEPROM(int deviceaddress, unsigned int eeaddress, char* data) {
// Uses Page Write for 24LC256
// Allows for 64 byte page boundary
// Splits string into max 16 byte writes
unsigned char i = 0, counter = 0;
unsigned int address;
unsigned int page_space;
unsigned int page = 0;
unsigned int num_writes;
unsigned int data_len = 0;
unsigned char first_write_size;
unsigned char last_write_size;
unsigned char write_size;
// Calculate length of data
do {
data_len++;
} while (data[data_len]);
// Calculate space available in first page
page_space = int(((eeaddress / 64) + 1) * 64) - eeaddress;
// Calculate first write size
if (page_space > 16) {
first_write_size = page_space - ((page_space / 16) * 16);
if (first_write_size == 0) first_write_size = 16;
first_write_size = page_space;
// calculate size of last write
if (data_len > first_write_size)
last_write_size = (data_len - first_write_size) % 16;
// Calculate how many writes we need
num_writes = ((data_len - first_write_size) / 16) + 2;
num_writes = 1;
i = 0;
address = eeaddress;
for (page = 0; page < num_writes; page++)
if (page == 0) write_size = first_write_size;
else if (page == (num_writes - 1)) write_size = last_write_size;
else write_size = 16;
Wire1.beginTransmission(deviceaddress);
Wire1.write((int)((address) >> 8)); // MSB
Wire1.write((int)((address) & 0xFF)); // LSB
counter = 0;
do {
Wire1.write((byte) data[i]);
i++;
counter++;
} while ((data[i]) && (counter < write_size));
Wire1.endTransmission();
address += write_size; // Increment address for next write
delay(100); // needs =>9ms for page write
void readEEPROM(int deviceaddress, unsigned int eeaddress,
unsigned char* data, unsigned int num_chars)
unsigned char i = 0;
Wire1.write((int)(eeaddress >> 8)); // MSB
Wire1.write((int)(eeaddress & 0xFF)); // LSB
Wire1.requestFrom(deviceaddress, num_chars);
while (Wire1.available()) data[i++] = Wire1.read();
Any ideas on how I can fix this please?
Thanks
