External input to pin
Is it possible to achieve the reverse of what this tutorial is describing:
http://arduino.cc/en/Tutorial/InputPullupSerial ?
I.E. Instead of using ground to change the input, use +5V for example. The reason I ask is because I need to check if there is voltage from an external source in order to satisfy my condition...
Yes, it is possible but not using Software. Just add an external pull-down resistor and you have what you're looking for.
Describe the external signal source. What I mean is, is the source either 5V or open (like a push-button wired to 5V) or is the source 5V and ground (like a TTL signal)?
groundfungus:
5V & GND. Are you going to suggest I just use the GND of the source? Is it possible?
EDIT:
Sorry misinterpreted your question. Upon better comprehension, yes it is 5V or open.
Pylon:
Thank you for your swift reply, I shall look into pull-downs :smiley:
