External Interrupt and millis() conflict
#include <SoftwareSerial.h>             //Use other pins for Serial
#include <RBDdimmer.h>                  //Dimmer Library
SoftwareSerial BTSerial(8, 9); // RX, TX
#define Light  6 //AC Load
dimmerLamp dimmer1(Light); //initialase port for dimmer for MEGA, Leonardo, UNO, Arduino M0, Arduino Zero
int data_pin = 7;
int interval1 = 2000;// Initialize Receiver value as 0.
unsigned long millis_1 = 0;
boolean result[41]; //holds the result
unsigned int temp; //in celcius
char c;
  BTSerial.begin(9600);
 dimmer1.begin(NORMAL_MODE, ON); //dimmer initialisation: name.begin(MODE, STATE)
 dimmer1.setState(OFF);
  if(millis() > millis_1 + interval1)
    millis_1 = millis();
    pinMode(data_pin, OUTPUT);
    digitalWrite(data_pin,LOW);
    delay(18);
    digitalWrite(data_pin,HIGH);
    pinMode(data_pin, INPUT_PULLUP);
    //read 41 bits of signal
 for(int i=0;i<=40;i++)
      result[i]=(pulseIn(data_pin, HIGH)>40);
    //Extract Temperature (from Byte 3)
    temp=0;
    for (int i=17;i<=24;i++)
      temp=temp<<1;
      if (result[i]) temp|=1;
    BTSerial.print("*T"+String(temp)+"*");
I'm dimming a AC light using the RBDimmer.h library and I'm also using a DHT11 Sensor. The Dimmer library has an external interrupt attached to pin 2 and this is preventing my serial monitor from displaying the temperature sensor value as the interrupt happens faster than i could extract my data from the DHT11 data pin. It only displays T0 every 2 seconds. I have tried to disable interrupt during the 18ms required for data aquisition from the DHT11 and then reenabling it after serial print. Unfortunately, I'm still getting the same results.
cli();
    delay(18);
I am only able to print the sensor values on the serial terminal when i comment this code
How do I prevent the external interrupt from screwing up my sensor read?
I'm not familiar with the library you are using - I presume it is linked to an external interrupt but we can't see the code it is using.
The pulseIn() function blocks and you have a blocking FOR loop that uses 40 of them.
...R
I see an immediate issue with your timing:
should be:
unsigned long interval1 = 2000;// Initialize Receiver value as 0.
Also:
  if (millis() > millis_1 + interval1)
should be:
  if (millis() - millis_1 > interval1)
Disabling interrupts during the reading is what both you and all the dht libraries do.
Your placement of cli() before a delay is wrong, as delay will not function with interrupts disabled.
Using the dht in the same sketch as a zero cross interrupt for ac dimming may be a loosing proposition, but I would suggest using the Adafruit libraries for the dht.
