I develop my own SAM3X8E based card with the arduino IDE, no issues with hardware.
I have done a lot of research without finding a solution that works. The documentation says that you can do an external interrupt with any pin. I can't seem to figure out how to do this when using an unmapped pin. attachInterrupt doesn't work in this case, I tried enableInterrup library, it's the same. If anyone can help me, I will appreciate it a lot. thank you in advance.
This sketch shows how attachinterrupt() works by simulating an input 125 KHz pulse provided by an internal Timer Counter (Connect a jumper between pin 2 and pin 11):
void ISR1() {
static uint32_t Count;
Count++;
if (Count > 125000) {
Count = 0;
PIOB->PIO_ODSR ^= PIO_ODSR_P27; // Toggle LED with a 1 Hz frequency
/************* Timer Counter 0 Channel 0 to generate PWM pulses thru TIOA0 ************/
PMC->PMC_PCER0 |= PMC_PCER0_PID27; // TC0 power ON - Timer Counter 0 channel 0 IS TC0
PIOB->PIO_PDR |= PIO_PDR_P25;
PIOB->PIO_ABSR |= PIO_ABSR_P25;
TC0->TC_CHANNEL[0].TC_CMR = TC_CMR_TCCLKS_TIMER_CLOCK1 // MCK/2, clk on rising edge
| TC_CMR_WAVE // Waveform mode
| TC_CMR_WAVSEL_UP_RC // UP mode with automatic trigger on RC Compare
| TC_CMR_ACPA_CLEAR // Clear TIOA0 on RA compare match
| TC_CMR_ACPC_SET; // Set TIOA0 on RC compare match
TC0->TC_CHANNEL[0].TC_RC = 336; //<********************* Frequency = (Mck/2)/TC_RC Hz = 125 KHz
TC0->TC_CHANNEL[0].TC_RA = 10; //<******************** Duty cycle = (TC_RA/TC_RC) * 100 %
TC0->TC_CHANNEL[0].TC_CCR = TC_CCR_SWTRG | TC_CCR_CLKEN; // Software trigger TC0 counter and enable
pinMode(LED_BUILTIN, OUTPUT);
attachInterrupt(11, ISR1, RISING);
thanks for the example.
But i still haven't figured out how to declare some pins with attachInterrupt.
e.g. for port B, how to declare PB0 to PB11 in attachInterrupt ?
I can't find digital pin name for this...
Exactly, but nothing for pin PB0 to PB11 in Graynomad !!! This is my problem...
I just saw that in my arduino / hardware installation I have nothing concerning the sam series. Is it normal ?
I can't find variants files for due or others...
Some Sam3x pins are not broken out on a DUE, hence you won't find them in the Pinout diagram.
2 possible workarounds:
1/ As stated in reply #5, alter the variant file. This file is located at:
.../packages/arduino/hardware/sam/1.6.x/Variants that you can easily find on your PC by clicking in the URL at the bottom of the window opened after selecting File/Preferences in an IDE window (C:\Users\xxx\AppData\Local\Arduino15\preference.txt)
2/ Program your own code to detect an external interrupt. It's a bit more complex but external interrupts can be processed much faster than with the arduino function attachInterrupt().
