External Interrupt @ t2313 doesnt work
Hello,
I'm trying to get this code working on my t2313:
byte led = 2;
volatile int dly = 500;
  pinMode(led, OUTPUT);
  digitalWrite(6,HIGH);    // pullups
  digitalWrite(7,HIGH);
  attachInterrupt(0, less_dly, LOW);
  attachInterrupt(1, more_dly, LOW);
  digitalWrite(led, HIGH);
  delay(dly);
  digitalWrite(led, LOW);
  delay(dly);
void less_dly() {
  dly = dly-10;
void more_dly() {
  dly = dly+10;
The t2313 is running at 1Mhz with this core: Google Code Archive - Long-term storage for Google Code Project Hosting. . Its not doing anything at all. Not even the loop() blinking. I'm thankful for any help!
Does the LED blink every 500ms if you comment-out the attachInterrupt calls?
Ok pretty stupid but I mixed the pins up. I was connecting the LED to pin2 (AVR) and not pin2 (Arduino). The pull up command was also wrong and needed to be changed to 4/5.
Now it works fine. Thank you for forcing me to check it again :slight_smile:
Arduino AVR (t2313)
- 1=RST
0 2=RX
1 3=TX
2 4=IO
3 5=IO
4 6=INT0
5 7=INT1
