External P/S for an Arduino?
Hello! Normally I run my Arduino Duemilanove via its USB portal, because it seems I am still writing and rewriting these sketches.
I've noticed that the board is wearing the standard coaxial power connector which tells me that it can be supported via the typical wall wart.
I've also during these runs attached things to the power portals on the connectors, can they be used to send power into the board?
After all it is typically running attached to a typical breadboard which has a power supply attached to it delivering 5v at a good delivery.
doctorwho8 ( Gregg C Levine ) Time moves in spirals.
http://arduino.cc/en/Main/ArduinoBoardDuemilanove
Section on Power explains different options to power the board.
Hello!
And thank you for confirming this discovery. I had an inspired guess regarding this particular board shortly after posting it, but I needed to have it confirmed.
doctorwho8 (Gregg C Levine) Time moves in spirals, because a straight line is too hard.
