External power for Sg 90 micor Servo motor
how to put external power supply for 90sg servo motor on a motor shield for a project of obstacle avoidance robot? and what is the adjustment on the code?
Welcome to the forum
Connect the positive and GND (negative) of the external supply to servo positive and GND (negative). Connect Arduino GND to servo GND. Connect the servo data wire to an Arduino pin as normal
No adjustment to code is required when using external power for the servo
Please post the details of your project here rather than a link to an external site
is any pin alright? we are to use 6 or 7 pin on the arduino
Showing how to connect an external power source with servo and Arduino.
Use any pin for the servo control signal. It does not have to be a PWM pin. You can use the analog inputs, too (except A6 and A7 on Nano).
is this right?
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
sorry, but this is our code
//ARDUINO OBSTACLE AVOIDING CAR//
// Before uploading the code you have to install the necessary library//
//AFMotor Library https://learn.adafruit.com/adafruit-motor-shield/library-install //
//NewPing Library https://github.com/livetronic/Arduino-NewPing//
//Servo Library https://github.com/arduino-libraries/Servo.git //
// To Install the libraries go to sketch >> Include Library >> Add .ZIP File >> Select the Downloaded ZIP files From the Above links //
#include <AFMotor.h>
#include <NewPing.h>
#include <Servo.h>
#define TRIG_PIN A0
#define ECHO_PIN A1
#define MAX_DISTANCE 200
#define MAX_SPEED 190 // sets speed of DC  motors
#define MAX_SPEED_OFFSET 20
NewPing sonar(TRIG_PIN, ECHO_PIN, MAX_DISTANCE);
AF_DCMotor motor1(1, MOTOR12_1KHZ);
AF_DCMotor motor2(2, MOTOR12_1KHZ);
AF_DCMotor motor3(3, MOTOR34_1KHZ);
AF_DCMotor motor4(4, MOTOR34_1KHZ);
Servo myservo;
boolean goesForward=false;
int distance = 100;
int speedSet = 0;
  myservo.attach(10);
  myservo.write(115);
  delay(2000);
  distance = readPing();
  delay(100);
  delay(100);
  delay(100);
  delay(100);
 int distanceR = 0;
 int distanceL =  0;
 delay(40);
 if(distance<=15)
  moveStop();
  delay(100);
  moveBackward();
  delay(300);
  moveStop();
  delay(200);
  distanceR = lookRight();
  delay(200);
  distanceL = lookLeft();
  delay(200);
  if(distanceR>=distanceL)
    turnRight();
    moveStop();
  }else
    turnLeft();
    moveStop();
 }else
  moveForward();
int lookRight()
    myservo.write(50);
    int distance = readPing();
    delay(100);
    myservo.write(115);
    return distance;
int lookLeft()
    myservo.write(170);
    delay(100);
    myservo.write(115);
    return distance;
    delay(100);
int readPing() {
  delay(70);
  int cm = sonar.ping_cm();
  if(cm==0)
    cm = 250;
  return cm;
void moveStop() {
  motor1.run(RELEASE);
  motor2.run(RELEASE);
  motor3.run(RELEASE);
  motor4.run(RELEASE);
void moveForward() {
 if(!goesForward)
    goesForward=true;
    motor1.run(FORWARD);
    motor2.run(FORWARD);
    motor3.run(FORWARD);
    motor4.run(FORWARD);
   for (speedSet = 0; speedSet < MAX_SPEED; speedSet +=2) // slowly bring the speed up to avoid loading down the batteries too quickly
    motor1.setSpeed(speedSet);
    motor2.setSpeed(speedSet);
    motor3.setSpeed(speedSet);
    motor4.setSpeed(speedSet);
    delay(5);
void moveBackward() {
    goesForward=false;
    motor1.run(BACKWARD);
    motor2.run(BACKWARD);
    motor3.run(BACKWARD);
    motor4.run(BACKWARD);
    delay(5);
void turnRight() {
void turnLeft() {
We used 4 AA for the external power for the servo motor and 3.7 li-ion for the main power source of the arduino. We are not quite sure if what we did is correct since most tutorial doesn't have motor shield on them
How was this battery connected to the Arduino and what was its actual voltage at the time ?
The li-ion is connected through M+ and GND sector directly, when we tested it the battery was fully charged so it was probably 4.2v at most. The robot is functioning but the servo was not rotating so we decided to give it external power, we just don't know if we did it right.
I am confused by what you are saying. How is the Arduino board itself powered and at what voltage ?
We used two 3.7v li-ion battery then connected it to the board
