In my use case, I need to drive 5 servo motors (sg 90) using arduino uno. I have a power adaptor rated at 9v 1A DC which i plan to use for arduino uno. For the servo motor power supply, i have a 12V 5A adaptor which i plan to convert to 5V 2A using buch convertors.
From this forum , it seems for servo motors the stall current is ~750mA but while running, i guess current requirement may be higher, So to have safety margin i decided to provide atleast 1A to each of the servo motor.
I have attached the circuit diagram with this post.
As the sg90 servo motor 1,2 and 3,4 are connected in parallel to the buck convertor (which is a power source), then we have 5 Volt 1Amp across each of the servo motors. For servo motor 5 we have 5v 2Amp at idle condition.
I have also added a 100uF polar capacitor to "stabilize" the voltage across the motors.
In my case, I may be required to run all the servo motors at a time, Is this power supply design safe for my use case? Please let me know in case something is vague / unclear in my post.
(mod edit)
