Thanks to Acleone, I connected 10 TLC5940 chips in control .
But then, next problem came up. LEDs on from 6th chip onward are dimmed and even blinking while LEDs on 1~5th chips are just constantly bright. It seems like 5 * TLC5940s are enough to dissipate all the power from arduino.
So, If I want to use more than 200 leds controlled by 15 TLC5940s, I definitely need to use external power supply, dont I? If so, how can I do it?
Somebody please tell me what I should do. .. Thanks in advance!
If you have an external power source plugged into the Arduino, you might be overloading the voltage regulator by drawing too much current through the +5V line. If you have 5*16 LEDs, this is 1.6A! of current. You could try powering all the LEDs from the external power supply directly: hook the positive legs of the LEDs to the "VIN" pin on the Arduino.
There are two power required for TLC5940 - one is directly into the chip (Vcc), another is VLed to LEDs. I understand that all GND should be shared but how about + when I use two sources of power?
(a). Vcc-5v on Arduino | VLed-5v from Vin (or EXT power)
(b). Vcc & VLed both - Vin
Which one is correct? Do they make any difference?
If I connect an external power to Arduino, its voltage should be 7~12 (arduino's recommendation) so the Vin is same as the external power which is too much for VLed. I might need to down the voltage with a resistor or regulator or something that I don't know how. Anybody can give me a hint?
you should power the chip from arduino (either 3.3v or 5v depending on your resistor for IREF).
what i meant to say in my post is that i have an external power supply for the LED's (not the TLC5940).... and a common ground between all three (the ground of the power supply is connected to ground on arduino and the TLC5940).
Note that if you are using 3V3 to power the TLC5940 you should not connect the anodes of the LED to +5V directly as this would take the inputs to the chip outside it's rails. There is a TI application note that shows the LEDs going through a FET with the gate set to Vcc in order to protect it.
If you are using 5V then everything is as stated above.
