External power supply questions
I know that you can power the arduino from an external supply, either via the 9v/gnd header pins, or with the center-positive plug. I was wondering what would happen if you did both at the same time? ie plugged in a wall-wart while the 9v battery was still connected. It’s not clear from the schematic how the plug and header are wired together.
Something else I’d like to know: if I have the arduino powered from a 9v battery, and then I plug it in to a wall-wart, will it cause a reset, or will it continue to operate as if nothing happened?
Does anyone have a source for 9v battery clips that have the center-positive plug on them? I suppose I could make one but it wouldn’t be very pretty.
Finally, how much current can be drawn off of the 5v header pin? I can’t tell the exact part numbers from the pictures or schematics, so I don’t know what the voltage regulator can handle.
Thanks,
I was wondering what would happen if you plugged in a wall-wart while the 9v battery was still
On my freeduino board, the 9v vin pin is connected to the input of the voltage regulator. The dc in socket connects to the regulator input through a diode.
So, in your scenario, the wall wart voltage (less the .7 diode voltage drop) would be applied across the battery. This is not a good idea. But if you connected the battery via a diode (similar to how the DC in is connected) then whichever had the higher voltage would provide power to the regular.
Depends on the regulator on your board. Could be anything from 250 ma to 1 amp. If the part numer of the regulator is legable then you should be able to find the specs on google.
I hope that helps
