External Pull Up Resistance ATMEGA328P
Hello all,
I am using 4 I/Os of an Arduino UNO to communicate with a GPS and a GSM modul but because it`s to big for my application I decided to create my own circuit board where I just use the ATMEGA328P.
The datasheet of ATMEGA328p says: "If some pins are unused, it is recommended to ensure that these pins have a defined level" & "If low power consumption during reset is important, it is recommended
to use an external pull-up or pull-down."
So I want to use a pull up resistor for that.
My question now is what is the usual resistance which is used in this case and how could I caltulate it?
I think I also have to define the unused I/Os as Inputs because of the 5V- Is it possible to define this in the IDE or where shoul this be done?
HannesM:
Why ?
Whats the problem with just defining all the unused pins as 'INPUT_PULLUP' if your worried about it ?
