External siren
Hello,
I'm working on this home made external siren for my alarm. Practically it exchanges 2 variables between the home alarm and the external siren. Alarm on and PanicBuzzer on.
Both devices are bridged with 2 wemos and connected with a dedicated AP.
I've written my code, but unfortunately the alarm main function is not working (only the first condition)
I have an earlier version where all the if conditions are broken up- nd everything is working.
i'm trying to rewrite the code for easier understanding. So I've put all the conditions together.
Would you please give me a hint on my logical fallacies?
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
#include <SimpleTimer.h>
#include <SPI.h>
#include <OneWire.h>
// Server declaration for variable exchange
IPAddress server(10, 0, 0, 201);     // fix IP of the server - GT HOUSE ALARM 2200
const int API_TIMEOUT = 1500;   //Connection timeout
WiFiClient client;
String answer;   //Variable exchange
//Debug mode
bool debug = 0;
//Variables ON OFF
bool ALM_ON;  //The alarm is active.
bool PANIC_ON;   //The alarm is in panic mode! Burglar inside!
bool Keys_ON;  //0= Keys in off position   1= Keys in on position
SimpleTimer timer;  //Timer function declaration
//For state change detection
int lastButtonState = 0;
int buttonState = 0;
//Monitor reed for anti tamper function
int state; // 0 close - 1 open wwitch
//Monitor Key function
int sensorVal; // 0 open alarm - 1  alarm working
//Hardware GPIOS
const int sensor = D2;   //reed
const int button = D5;   //Key
const int RDH1 = D4;  //Big led
const int LWH2 = D6;  //Small led
const int RELE = D1;  //Relay
const int resetPin = D7;  //Reset enable
//Network configuration
const char * ssid = "ESPsoftAP_Gt2200"; //your wifi ssid
const char * password = ""; //your wifi password
IPAddress ip(192, 168, 4, 1); //your arduino IP
IPAddress gateway(192, 168, 4, 1); //your network gateway
IPAddress subnet(255, 255, 255, 0); //your network subnet mask
  Serial.begin(74880);
  // WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  WiFi.config(ip, gateway, subnet);
//Configurazione di default Gpio
  pinMode(button, INPUT_PULLUP);
  pinMode (LWH2, OUTPUT);
  pinMode (RDH1, OUTPUT);
  pinMode (resetPin, OUTPUT);
  pinMode (RELE, OUTPUT);
  pinMode (sensor, INPUT_PULLUP);
  digitalWrite(LWH2, LOW);
  digitalWrite(resetPin, HIGH);
  digitalWrite(RDH1, LOW);
  digitalWrite(RELE, HIGH);
 //Scantime simpletimer functions
  timer.setInterval(50L, disable);
  timer.setInterval(100L, alarm);
  while ( client.connect(server, 80))
  { // connects to the server
    Serial.println(" Connected to Gt2200 ");
    client.println("Send data!\r");    // trigger message to the server, its value is scrapped
    answer = client.readStringUntil('\r');  // received the server's answer
    client.flush();
    ALM_ON = answer.substring(0, answer.indexOf(',')).toInt();
    PANIC_ON = answer.substring(answer.indexOf(',') + 1).toInt();
    Serial.print("ALM_ON: ");
    Serial.println(ALM_ON);
    Serial.print("PANIC_ON: ");
    Serial.println(PANIC_ON);
    timer.run();   //Simpletimer functions call
    delay (600);
  } yield();
    Serial.println("not connected");   //Flash small led while connecting to the internet
    digitalWrite(LWH2, HIGH);
void disable()  //Keys function - check if they are turned off (0) or turned on (1)
  sensorVal = digitalRead(button);
  Serial.print("SCAN: for key pressed");
  //Serial.print(sensorVal);
  Serial.print(" ");
  delay(50);
  if  (sensorVal == LOW)
    Serial.print("KEY ON\n");
    Keys_ON = 1;
    delay(50);
    Serial.print("KEY OFF\n");
    Keys_ON = 0;
    delay(50);
void alarm()
  state = digitalRead(sensor);
  Serial.print("Reed state 0= Closed 1=Opened: ");
  Serial.print(state);
    Serial.print("\n");
  if ((ALM_ON == 1) && (Keys_ON == 1))              //if the keys are turned and the alarm is on, keep flashing big LED
      Serial.print("Lights on");
      digitalWrite(RDH1, HIGH);
      delay(2000);
  else if ((ALM_ON == 1) && (Keys_ON == 1) && (PANIC_ON == 1))   //Main function: Sound the external siren when Gt2200 is in PANIC mode.
      Serial.print("WORKING: Alarm and Buzzer ");
      digitalWrite(RELE, LOW);
      delay(22000);  //Time for buzzer
      digitalWrite(resetPin, LOW);  //After the alarm has gone on, reset arduino, to exit cycle
 else if (((Keys_ON == true) && (state == HIGH)) || ((Keys_ON == true) && (state == HIGH) && (ALM_ON == true)))    //Tamper function: sound the alarm in case somebody is opening the box without permission
     Serial.print(" working: Alarm - TAMPERED");
  else if ((Keys_ON == 0) && (PANIC_ON == 1))   //Signal for malfunction  small led on in case the alarm goes off while the keys are off - No buzzer
  Serial.print("Malfunction");
