External Voltage supply
I have some stepper motors to power so I need to use some external voltage source, I chose LM317 circuit from datasheet and Li-po battery(1700 mAh 25C)
How I can put it into use ? Positive wire to L293D leg which supply power for stepper motor , negative one to gnd of arduino ?
I tried this but It fail a bit... Where is mistake ? How to connect them.
Look at the data sheet and you will see it is more complex than this.
You need a potential divider and decoupling capacitors.
I know, I build 1.2V-25V voltage regulator from typical application section. But I see my mistake right now ....
http://www.ti.com/lit/ds/symlink/lm117.pdf Input voltage should be more or equal 28V. I connected far less ...
No the input voltage must be a few volts more than the output voltage not more that 28V. That first diagram is for a regulator that goes up to 25V.
Ok so I had circuit from this diagram except Resistor 240 ohms - I had only 220 ohms so I used it.
It works properly, using a pot I can change voltage. I set it to 3.3V and put positive terminal to leg on L293D corresponding for supplying motor. Negative one to GND of same IC and... nothing.
This is because, according to the data sheet, the motor supply has to be at lease the same voltage as the chip's logic supply voltage. In other words it will not work with only 3V3.
Bear in mind that the voltage supplied by the L293D to the stepper motor will be 2 to 3v less than the supply voltage you feed to its Vcc2 pin.
