Hello,
I have an relay, that works great, when I connect it directly to the power of the Arduino.
But when I connect it to an external power supply instead, it does never turn off (it is active low).
I think I did the wiring correctly, please take a look. Any help is greatly appreciated!
EDIT: If I remove the connection between relay in and the pin, the relay turns off. If I connect it directly to the breadboard, it turns on again, which is expected since its active low.
WIRING:
- black cable: relay vcc «» 5v block +
- yellow cable: relay gnd «» breadboard
- purple cable: 5v block - «» breadboard
- orange cable: arduino gnd «» breadboard
- blue cable: arduino P5 «» relay in
CODE:
// Define relay pins
#define RELAY1 5 // Arduino Pin D5 (Relay 1)
#define RELAY2 6 // Arduino Pin D6 (Relay 2)
#define RELAY3 7 // Arduino Pin D7 (Relay 3)
// Setup function
// Initialize relay pins as output
pinMode(RELAY1, OUTPUT);
pinMode(RELAY2, OUTPUT);
pinMode(RELAY3, OUTPUT);
// Start serial communication at 9600 baud rate
// Turn off all relays initially
digitalWrite(RELAY1, HIGH);
digitalWrite(RELAY2, HIGH);
digitalWrite(RELAY3, HIGH);
Serial.println("Relay Controller Ready");
// Loop function
// Wait for a command from Serial Monitor
if (Serial.available() > 0) {
char command = Serial.read(); // Read the incoming command
// Process the command
switch (command) {
case '1': // Turn Relay 1 ON
digitalWrite(RELAY1, LOW); // Active low, turn ON
Serial.println("Relay 1 ON");
case '2': // Turn Relay 1 OFF
digitalWrite(RELAY1, HIGH); // Active low, turn OFF
Serial.println("Relay 1 OFF");
case '3': // Turn Relay 2 ON
digitalWrite(RELAY2, LOW); // Active low, turn ON
Serial.println("Relay 2 ON");
case '4': // Turn Relay 2 OFF
digitalWrite(RELAY2, HIGH); // Active low, turn OFF
Serial.println("Relay 2 OFF");
case '5': // Turn Relay 3 ON
digitalWrite(RELAY3, LOW); // Active low, turn ON
Serial.println("Relay 3 ON");
case '6': // Turn Relay 3 OFF
digitalWrite(RELAY3, HIGH); // Active low, turn OFF
Serial.println("Relay 3 OFF");
default:
Serial.println("Invalid Command");
R1_ON = b"1"
R1_OFF = b"2"
arduino = serial.Serial('/dev/ttyACM0', 9600)
arduino.write(R1_ON)
arduino.write(R1_OFF)
