Extract a date from a sentence
Hello,
I want to extract the date (dd/mm/yy) from a NMEA gps phrase.
It looks like this:
$GPRMC,225446,A,4916.45,N,12311.12,W,000.5,054.7,191194,020.3,E68*
Here the date is November 19, 1994.
I could do by counting where to take the digits but I would prefer, to be sure of the reliability of the result, to position myself after the 9th comma (where the date begins) then extract these 6 digits.
But how to do this in Arduino code?
Link to inquire about GPRMC sentence: GPRMC
strtok is the word your google for.
Thank you very much !
It works very well and it's simple.
Is there a way to do it cleaner or with less code even if it's already not bad?
void setup(void) {
  char *token;
  char *mystring = "$GPRMC,225446,A,4916.45,N,12311.12,W,000.5,054.7,191194,020.3,E68*";
  const char *delimiter = ",";
  int t = 0;
  token = strtok(mystring, delimiter);
  while (!(t == 9)) {
    token = strtok(NULL, delimiter);
    t++;
  Serial.println(token);
void loop(void) {
If you use a library like TinyGPS++, dates and everything else of interest is extracted automatically.
http://arduiniana.org/libraries/tinygpsplus/
I would use one of the GPS libraries. My favorite is TinyGPS++ (a.k.a. TinyGPSPlus). There are also TinyGPS and Adafruit_GPS_Library.
For now the NMEA sentence was enough for me (perfect to be converted into gpx) so I didn't need a library.
I may use this library to improve my project.
But sometimes it might be better to do the code yourself and figure it out?
