Extract data from file, save them in variables then call the data to function
PLEASE HELP
Hello everyone,, Im reading distance>10 from ultrasonic sensor, save them in a file with timestamp, in every 24hrs I want to call and save the data in variables for analysis in a function
Qn: I want to call every sensor data (distance) from file and put them in ranges ie (50-80, 110-140)cm, then finally count how many classes of data I have. e.g considering data below I have two classes of data
my file data is as follows
hr:min:sec dt:mn:yr= sensor data(distance)
17:22:51-14/8/2020= 57cm
17:22:52-14/8/2020= 119cm
17:22:53-14/8/2020= 70cm
17:22:55-14/8/2020= 114cm
Thanks for your patience, Eddy
Here is my code
#include <SPI.h>
#include <SD.h>
#define trigPin 3
#define echoPin 2
#include <RF24.h>
#include <DS1307RTC.h>
#include <Time.h>
#include <Wire.h>
int counter = 0;
long distance;
long duration;
const int chipSelect = 10;
File myFile;
String time ;
tmElements_t tm;
 pinMode(trigPin, OUTPUT);
 pinMode(echoPin, INPUT);
 Serial.println("ArduinoAll DataLogger Shield Test");
 pinMode(SS, OUTPUT);
 if (!SD.begin(chipSelect)) {
   Serial.println("SD Card initialization failed!");
   return;
 Serial.println("SD Card OK.");
 //ReadText();
void WriteText(String txt) {
 myFile = SD.open("test.txt", FILE_WRITE);
 if (myFile) {
   myFile.println(txt);
   myFile.close();
 else {
   // if the file didn't open, print an error:
   Serial.println("error opening test.txt");
long readUltrasonicSensor(){
 // Send 10µs pulse
 digitalWrite(trigPin, HIGH);
 delayMicroseconds(10);
 digitalWrite(trigPin, LOW);
 // Read pulse duration
 duration = pulseIn(echoPin, HIGH);
// Serial.println(duration); //Convert and return value
 return duration/ 58;
String Now() {
 String time = "";
 if (RTC.read(tm)) {
   //    time = String(tm.Hour+":"+tm.Minute+":"+tm.Secnd+" DAY : "+tm.Day+"/"+tm.Month+"/"+tmYearToCalendar(tm.Year));
   time += tm.Hour;
   time += ":";
   time += tm.Minute;
   time += ":";
   time += tm.Second;
   time += "-";
   time += tm.Day;
   time += "/";
   time += tm.Month;
   time += "/";
   time += tmYearToCalendar(tm.Year);
 else {
   time = "NO";
   if (RTC.chipPresent()) {
     Serial.println("The DS1307 is stopped.  Please run the SetTime");
     Serial.println("example to initialize the time and begin running.");
     //Serial.println();
   else {
     Serial.println("DS1307 read error!  Please check the circuitry.");
     //Serial.println();
 return time;
void analysis(){
myFile = SD.open("test.txt");
if (myFile) {
  Serial.println("tet.txxt:");
char buffer[50]; // May need to be a bit bigger if you have long names
byte index = 0;
while (myFile.available())
     char c = myFile.read();
      if(c == '\n' || c == '\r') // Test for <cr> and <lf>
          parseAndSave(buffer);
          index = 0;
          buffer[index] = '\0'; // Keep buffer NULL terminated
          buffer[index++] = c;
  myFile.close();
else {
distance=readUltrasonicSensor();
  if ( distance > 10 )
time = Now() + "= "+distance;
 WriteText(time);
void parseAndSave(char *buff)
  char *name = strtok(buff, "=");
  if(name)
      char *junk = strtok(NULL, " ");
      if(junk)
          char *valu = strtok(NULL, " ");
          if(valu)
              int val = atoi(valu);
              if(strcmp(name, distance) == 0)
                   int distance1 = val;
What do you need help with?
It looks like you have functions for reading and parsing the data. All that remains is the counting into ranges which sounds simple enough.
Thanks wildbill for your time, Im a beginner to coding, can you show me with a code how I can count into ranges, thanks in advance
Eddy
(deleted)
