Extracting characters from serial data ??
Hi everyone
I have an arduino connected to a sensor via MAX3232 and a RS232 cable.
Getting the data from the sensor is working fine.
How do i take only a portion of the returned data out (from data[71] to data[78]), and store it in a variable, so i can compare it to a preset value ?
I have tried to concatenate the data in various ways, but all i get is strange characters in the output…
My data is looking like this:
MD03 011 +7900-03 00 00 001 000000 012 +1100-02 00 00 001 000000 013 +1890-02 00 00 001 000000
Here is my code:
#include <NewSoftSerial.h>
NewSoftSerial mySerial(6, 7);
char incomingByte;
char data[200];
int i = 0;  //counter
mySerial.begin(9600);
  mySerial.print(0x02, BYTE);  // STX
  mySerial.print("DA");
  mySerial.print(0x0D, BYTE); // CR
 i = 0;
 while (mySerial.available() > 0)
  char charData = (char)mySerial.read();   //Read the buffer
  data[i] = charData;                              //Fill data into array
  i++;
  if (charData == 0x0D)                          //If CR then we have a full line
 if (mySerial.overflow()) Serial.print("Buffer overflow - Characters lost!");
 //int j = 0;
 //for (j=0; j < i; j++) Serial.print(data[j]);  //Send data to PC
 Serial.print(data[71]);
 Serial.print(data[72]);
 Serial.print(data[73]);
 Serial.print(data[74]);
 Serial.print(data[75]);
 Serial.print(data[76]);
 Serial.print(data[77]);
 Serial.print(data[78]);
I didn't count the characters, but if you don't care about data[79] you can do this
data[79] = '\0';
Serial.println (&data[71]);
EDIT: Sorry, I just looked at the printing part. Something similar may still work, it depends on the answers to Pauls' question.
Rob
Copying the data from one array to another is trivial, using a for loop with two index variables.
char data[200];
char copy[9];
for(int i=71, j=0; i<=78; i++, j++)
   copy[j] = data[i];
copy[8] = '\0';
Doing something with that copied data is a different story.
What is this preset value? A character array (strcmp() would be useful) or an int (int copyVal = atoi(copy))?
This was exactly what i needed :slight_smile:
char copy[9];
   copy[j] = data[i];
copy[8] = '\0';
What exactly does the ‘\0’ do/mean ?
I want compare the retrieved value, eg: “+1370-02” to a preset value of “+1000+01”, so i guess i should use strcmp()
It delimits the characters, essentially turning an array of chars into a NULL-terminated string.
Only if you are interested in an exact match, if you need <> numeric values then you have to convert the strings.
If you are just comparing strings then the method I proposed should work
data[79] = '\0';
if (0 == strcmp ("+1000+01", &data[71]))
   // strings are equal
Rob
Character escape sequences are in backslash notation as defined in ANSI X3.159-1989 (`ANSI C’).
The characters and their meanings are as follows:
\e Write an character.
\a Write a character.
\b Write a character.
\f Write a character.
\n Write a character.
\r Write a character.
\t Write a character.
\v Write a character.
’ Write a character.
\ Write a backslash character.
\num Write an 8-bit character whose ASCII value is the 1-, 2-,
or 3-digit octal number num.
To load the actual numbers from the string into variables, in case you don't end at comparison for exact match, use sscanf. Examples are at cplusplus.com
