Extracting info from a JSON return
I am using an ESP8266 chip & doing a http Post to my REST API server.
int httpCode = http.POST(json); // Send the request
String payload = http.getString(); // Get the response Serial.print("httpCode = "); Serial.println(httpCode); // Print HTTP return code Serial.print("Payload = "); Serial.println(payload); // Print request response payload Serial.print("Stuff here = "); Serial.println(""); http.end(); // Close connection
I am receiving a response back from the API which is giving me a httpCode (of say 201, 400 or -11(?)) & the payload is being output as the following example:
{"code":141,"error":"Device has a different MAC address."}
I now want to extract the code element into a variable which I will output below "Stuff Here". I've tried http.getString(code), but this isn't the right syntax & I get an error.
How would I do this?
Thanks
The "code element" has a name and a value ("code" and 141). Which do you want in the variable?
There is a JSON parser library for the Arduino...
I'm looking for the value (in my example 141).
Thanks
Presumably this is the parser you're referring to?
https://github.com/bblanchon/ArduinoJson
thomascoope: Presumably this is the parser you're referring to?
Yes.
Ace! Figured it. Thanks for your help.
I did it with the following code (having installed the ArduinoJSON library quoted above):
// Add the library
#include <ArduinoJson.h>
// Code (after JSON submission
StaticJsonBuffer<500> jsonBuffer;
JsonObject& root = jsonBuffer.parseObject(http.getString());
const char* code = root[“code”];
Serial.print("Code return element = ");
Serial.println(code);
const char* code = root["code"];
What you are getting is the value of the code element. It would be better to use a name like codeValue to reflect that.
And, of course, your print() statement should reflect that, rather than looking like a patch up of the example. 8)
Understood. I've done this now. Thank you greatly for your assistance.
