is there any function or a code that returnes the decimal digits of a float ?
for example: I have float A = 12.345678 but I'd like to get an int B = 5678 of that float.
P.S. I actually don't know the value of A, so multiplying A by 10e6 and then substracting 12340000 isn't possible. I just assigned a value to A here to make the problem clear, but it's for sure that the float value will have the same structure as A (two digits before the decimal point and 6 digits after it)
If you have any float value, storing it in an int will give the integer portion.
float f = 12.345678;
int i = f; // i will be 12
float d = f - i; // d will be 0.345678
d *= 100; // d will be 34.5678
i = d; // i will be 34
d -= i; // d will now be 0.5678
d /= 100.0; // d will now be APPROXIMATELY 0.005678
Or, it you want the value 5678 as an int, multiply by 10000 instead of dividing by 100.
Note that a float can not hold 8 digits of precision as your example alludes to.
I'm working with Latitudes and Longitudes and since processing floats takes more time that processing integers and due to the fact that the lats always have the same first 2 digits and the same first decimal digits (similiary lons), I thought that I could get rid of those digits and work with the last 4 or 5 decimal digits as integers
you mentioned that lats and lons come as strings from GPS and converting them would loosen the accuracey.....so my reply to that: in the code from david, they are definded and returned as floats.
MrMajd:
That David's code allowed for inaccurate handling of lat/lon values does not mean that yours has to.
MrMajd:
It pains me to say such an obvious thing, but "So, change the code from David (whoever he is)"
Our Finance Minister, almost in all occasions, broadcasts the word Nonsense regardless of the contexts. People took a long time to discover that the word was not an insult to them; rather, the Minister was educated in the West where Nonsense is a vocabulary.
AWOL:
I'd like to, but I'm still a beginer in programming and the code he's a bit complicated for me, however it works
If you have the time, could you take a look at the code and help me get it exactly (for example, changing it so that lats and lons are strings and not floats) thanks
How many calculations are you going to do ? sure floating point calculation is slow compared to integer calculations, but these microprocessors are might quick (compared to the Z80 i started out with)
