Extracting the weekday into an array.
Hi I got troble by extraction an array from an array.
static int WeekdayNr;
String     Weekday;
char dayOfTheWeek[12] ;
char daysOfTheWeek[8][12] = {"Noday","Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
Wereas
  Weekday = daysOfTheWeek[WeekdayNr];          // works well
  dayOfTheWeek = daysOfTheWeek[WeekdayNr];  // returns exit status 1 invalid array assignment
Who knows how to code it right?
Thank you.
Use strcpy()
Another common method is not to copy the char array, but to set a pointer to point to the particular element you want. I’ve seen that method used in several of the time related libraries that have functions to return the text for days or months.
char * dayOfTheWeek;
char daysOfTheWeek[8][10] = {"Noday", "Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
You should use:
char* Days[9]{Noday, Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, Saturday, \0}
So you have to use Days[1] for Sunday and Day[7] for Saturday.
ArnavPawarAA:
You should use:
There is no difference with RIN67630's original array. Except that yours probably will bot compile due to missing "s. Why do you have \0 at the end?
The correct syntax would be
const char * daysOfTheWeek[8] = {"Noday", "Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
That will save you a very slight amount of memory, because it only uses as much memory as needed to store the text, but adds two bytes per string as storage for the pointer.
david_2018:
Thank you, declared that way it works!
