Exxpected primary-expression before 'int'
I am having an error with a code
// Define pin 10 for buzzer, you can use any other digital pins (Pin 0-13)
const int buzzing = 3;
// Change to 0.5 for a slower version of the song, 1.25 for a faster version
const float songspeed = 1.0;
#define NOTE_C4  262   //Defining note frequency
#define NOTE_D4  294
#define NOTE_E4  330
#define NOTE_F4  349
#define NOTE_G4  392
#define NOTE_A4  440
#define NOTE_B4  494
#define NOTE_C5  523
#define NOTE_D5  587
#define NOTE_E5  659
#define NOTE_F5  698
#define NOTE_G5  784
#define NOTE_A5  880
#define NOTE_B5  988
int notes[] = {
    NOTE_E4, NOTE_G4, NOTE_A4, NOTE_A4, 0,
    NOTE_A4, NOTE_B4, NOTE_C5, NOTE_C5, 0,
    NOTE_C5, NOTE_D5, NOTE_B4, NOTE_B4, 0,
    NOTE_A4, NOTE_G4, NOTE_A4, 0,
    NOTE_A4, NOTE_C5, NOTE_D5, NOTE_D5, 0,
    NOTE_D5, NOTE_E5, NOTE_F5, NOTE_F5, 0,
    NOTE_E5, NOTE_D5, NOTE_E5, NOTE_A4, 0,
    NOTE_A4, NOTE_C5, NOTE_B4, NOTE_B4, 0,
    NOTE_C5, NOTE_A4, NOTE_B4, 0,
    NOTE_A4, NOTE_A4,
    //Repeat of first part
    //End of Repeat
int durations[] = {        //duration of each note (in ms) Quarter Note is set to 250 ms
  125, 125, 250, 125, 125,
  125, 125, 375, 125,
  125, 125, 375, 125,
  125, 125, 125, 250, 125,
  250, 125, 250, 125,
  125, 125, 375, 375,
  250, 125,
  //Rpeat of First Part
  125, 125, 375, 125,
  125, 125, 375, 125,
  250, 125, 250, 125,
  125, 125, 375, 375,
  //End of Repeat
  250, 125, 375, 250, 125, 375,
  125, 125, 125, 125, 125, 125, 125, 125, 375,
  125, 125, 125, 125, 125, 500,
  for (int i=0;i<203;i++){              //203 is the total number of music notes in the song
  int wait = duration[i] * songspeed;
  tone(buzzing,notes[i],wait);          //tone(pin,frequency,duration)
  delay(wait);}                        //delay is used so it doesn't go to the next loop before tone is finished playing
  //You can click reset on Arduino to replay the song
// Defining frequency of each music note
#define NOTE_C4 262
#define NOTE_D4 294
#define NOTE_E4 330
#define NOTE_F4 349
#define NOTE_G4 392
#define NOTE_A4 440
#define NOTE_B4 494
#define NOTE_C5 523
#define NOTE_D5 587
#define NOTE_E5 659
#define NOTE_F5 698
#define NOTE_G5 784
#define NOTE_A5 880
#define NOTE_B5 988
// Music notes of the song, 0 is a rest/pulse
int notes[] = {
    NOTE_A4, NOTE_A4,
    //End of Repeat
    NOTE_E5, 0, 0, NOTE_F5, 0, 0,
    NOTE_E5, NOTE_E5, 0, NOTE_G5, 0, NOTE_E5, NOTE_D5, 0, 0,
    NOTE_D5, 0, 0, NOTE_C5, 0, 0,
    NOTE_B4, NOTE_C5, 0, NOTE_B4, 0, NOTE_A4,
    NOTE_B4, NOTE_C5, 0, NOTE_B4, 0, NOTE_A4};
// Durations (in ms) of each music note of the song
// Quarter Note is 250 ms when songSpeed = 1.0
int durations[] = {
    125, 125, 375, 125,
    125, 125, 375, 125,
    250, 125, 250, 125,
    125, 125, 375, 375,
    250, 125,
    125, 125, 375, 125,
    125, 125, 375, 125,
    250, 125, 250, 125,
    125, 125, 375, 375,
    //End of Repeat
    125, 125, 125, 125, 125, 500};
  const int totalNotes = sizeof(notes) / sizeof(int);
  // Loop through each note
  for (int i = 0; i < totalNotes; i++)
    const int currentNote = notes[i];
    float wait = durations[i] / songSpeed;
    // Play tone if currentNote is not 0 frequency, otherwise pause (noTone)
    if (currentNote != 0)
      tone(buzzer, notes[i], wait); // tone(pin, frequency, duration)
      noTone(buzzer);
    // delay is used to wait for tone to finish playing before moving to next loop
    delay(wait);
  // Nothing in loop. Music only plays once.
  // You can click reset on Arduino to replay the song.
I get the error message
sketch_feb18a:105:1: error: expected primary-expression before 'int'
sketch_feb18a:105:1: error: expected '}' before 'int'
C:\Users\james`Preformatted text`\Documents\Arduino\sketch_feb18a\sketch_feb18a.ino: In function 'void setup()':
sketch_feb18a:161:14: error: 'duration' was not declared in this scope
C:\Users\james\Documents\Arduino\sketch_feb18a\sketch_feb18a.ino:161:14: note: suggested alternative: 'union'
              union
C:\Users\james\Documents\Arduino\sketch_feb18a\sketch_feb18a.ino: At global scope:
sketch_feb18a:184:11: error: redefinition of 'int notes []'
 int notes[] = {
C:\Users\james\Documents\Arduino\sketch_feb18a\sketch_feb18a.ino:61:5: note: 'int notes [1]' previously defined here
 int notes[] = {
sketch_feb18a:227:1: error: expected primary-expression before 'void'
sketch_feb18a:227:1: error: expected '}' before 'void'
sketch_feb18a:177:17: error: expected unqualified-id before numeric constant
 #define NOTE_E5 659
C:\Users\james\Documents\Arduino\sketch_feb18a\sketch_feb18a.ino:234:5: note: in expansion of macro 'NOTE_E5'
sketch_feb18a:237:45: error: expected declaration before '}' token
exit status 1
expected primary-expression before 'int'`
Missing something there.
And then you've got the problems of those redefinitions.
Looks like you are missing the closing brace of the setup() function and the closing brace and semicolon of the notes[] array
Wrong name for the array
The notes[] array is declared twice
Maybe more problems but I stopped looking
for a start you missed a terminating }; on the of notes[]
int notes[] = {
last line of notes has a trailing , get rid of it and it should compile. Error is last code line BEFORE error, not flagged line itself.
Sadly, unlikely.
Which is perfectly valid syntax. History.
google it.
read here
a7
