ez expander
hello,
i would like to do this program
int led[14] = { 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13}; // Assign the pins for the leds
int leftChannel = 0;  // left channel input
int left, i;
for (i = 0; i < 14; i++)  // Tell the arduino that the leds are digital outputs
  pinMode(led[i], OUTPUT);
//  Serial.begin(9600); // Uncomment to enable troubleshooting over serial.
left = analogRead(leftChannel);  // read the left channel
// Serial.println(left);  // uncomment to check the raw input.
left = left / 50;    // adjusts the sensitivity
//  Serial.println(left);  // uncomment to check the modified input.
// left = 1500;  // uncomment to test all leds light.
// left = 0;    // uncomment to check the leds are not lit when the input is 0.
  if (left == 0)  // if the volume is 0 then turn off all leds
   for(i = 0; i < 14; i++)
     digitalWrite(led[i], LOW);
   for (i = 0; i < left; i++) // turn on the leds up to the volume level
     digitalWrite(led[i], HIGH);
    for(i = i; i < 14; i++)  // turn off the leds above the voltage level
but with more outputs
so i have bought an ez-expander.
but i don't know how to use it
can you help me to do the program please ; )
for summary
i would to do this :
