Facebook likes Tweak
Hi, im begginer with arduino (learning basic electronics at this point). I menaged to make 2 projects by myself (i mean to copy other solutions via some diy). I want to learn more! It will consume a lot of time and i'm aware of it. So that is why im asking you for help at this point (need to improve 1 diy project that i found on web).
Recently i discovered that there are "shields". I never used that before. So those shields will give me some pin connectors to make more improvements? for example blinking led strip or buzzer?
here you have link: Facebook Like Box | Skolti
and i would like to combine it with this:
http://www.instructables.com/id/Facebook-Like-Monitor/
I want to add vibration and color blinking led strip (those are 12v?)/led like in seccond link
Is it possible to do that on those shields?
 Facebook Like Box
 This sketch connects to Facebook using an Ethernet shield. It parses the XML
 returned, and looks for <fan_count>this is a tweet</fan_count>
 You can use the Arduino Ethernet shield, or the Adafruit Ethernet shield,
 either one will work, as long as it's got a Wiznet Ethernet module on board.
 This example uses the DHCP routines in the Ethernet library which is part of the
 Arduino core from version 1.0 beta 1
 This example uses the String library, which is part of the Arduino core from
 version 0019.
 This example uses a Display Shield to display de results of the call to facebook.
 Circuit:
 * Ethernet shield attached to pins 10, 11, 12, 13
 * LCD Display shield attached to pins 8, 9, 4, 5, 6, 7
 created in 8 Aug 2012
 by David Alcubierre
 Ethernet part based on 'Twitter Client' by Tom Igoe (public domain, http://arduino.cc/en/Tutorial/TwitterClient).
 This code is in the public domain.
#include <SPI.h>
#include <Ethernet.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd( 8, 9, 4, 5, 6, 7 );
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x01 };
IPAddress ip(192,168,1,20);
// initialize the library instance:
EthernetClient client;
const unsigned long requestInterval = 12000;  // delay between requests
char serverName[] = "api-read.facebook.com";  // facebook URL
boolean requested;                   // whether you've made a request since connecting
unsigned long lastAttemptTime = 0;            // last time you connected to the server, in milliseconds
String currentLine = "";            // string to hold the text from server
String fbcount = "";                  // string to hold the tweet
boolean readingFbcount = false;       // if you're currently reading the tweet
  // reserve space for the strings:
  currentLine.reserve(256);
  fbcount.reserve(100);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // attempt a DHCP connection:
  Serial.println("Attempting to get an IP address using DHCP:");
  if (!Ethernet.begin(mac)) {
    // if DHCP fails, start with a hard-coded address:
    Serial.println("failed to get an IP address using DHCP, trying manually");
    Ethernet.begin(mac, ip);
  Serial.print("My address:");
  Serial.println(Ethernet.localIP());
  // connect to Twitter:
  connectToServer();
  if (client.connected()) {
    if (client.available()) {
      // read incoming bytes:
      char inChar = client.read();
      // add incoming byte to end of line:
      currentLine += inChar;
      // if you get a newline, clear the line:
      if (inChar == '\n') {
        currentLine = "";
      // if the current line ends with <fan_count>, it will
      // be followed by the tweet:
      if ( currentLine.endsWith("<fan_count>")) {
        // tweet is beginning. Clear the tweet string:
        readingFbcount = true;
        fbcount = "";
      // if you're currently reading the bytes of the facebook count,
      // add them to the tweet String:
      if (readingFbcount) {
        if (inChar != '<') {
          fbcount += inChar;
        else {
          // if you got a "<" character,
          // you've reached the end of the facebo:
          Serial.println(fbcount);
          lcd.begin(16, 2);
          lcd.print("Boing Boing likes");
          lcd.setCursor(0,7);
          lcd.print(fbcount);
          // close the connection to the server:
          client.stop();
  else if (millis() - lastAttemptTime > requestInterval) {
    // if you're not connected, and two minutes have passed since
    // your last connection, then attempt to connect again:
    connectToServer();
void connectToServer() {
  // attempt to connect, and wait a millisecond:
  Serial.println("connecting to server...");
  String content = "";
  if (client.connect(serverName, 80)) {
    Serial.println("making HTTP request...");
    // make HTTP GET request to Facebook:
    client.println("GET /restserver.php?format=xml&method=fql.multiquery&pretty=0&queries={%22page_info%22%3A%22select%20name%2Cfan_count%2Cpage_url%2Ctype%20from%20page%20where%20page_id%20IN%20(27479046178)%22}&sdk=joey HTTP/1.1");
    // declare correct server
    client.print("HOST: " + content.concat(serverName));
    client.println();
  // note the time of this connect attempt:
  lastAttemptTime = millis();
You can add LEDs to any Arduino, whether it is wearing a shield, or not, as long as you add them to pins that the shields are not using.
