Facing Button press issue
I am facing challenge that when i press button, it skips values not stable might be taking multiple times pressing values. i press single time and changed debounce time in code but not resolved.
please review my code. Its a Clock project with Max7219 and DS3231
DataIn/DIN                D12
CLK			  D11
LOAD/CS			  D10
SCL 			A5
SDA				A4
SQW
Menu Set	 	Button D3
Increment 		Button D4
Decrement 		Button D5
#include <LedControl.h>
#include <DS3231RTC.h>
#include <MyFont.h>
#include <ezButton.h>
byte devices = 4;
byte bright = 5; // Default intensity/brightness (0-15)
LedControl lc = LedControl(12, 11, 10, devices);
// pin 12 is connected to the DataIn on the display
// pin 11 is connected to the CLK on the display
// pin 10 is connected to LOAD on the display
/*      Clock Modes
        AM Mode         0
        PM Mode         1
        24 Hour Mode    2 */
const byte AMhr = 0;
const byte PMhr = 1;
const byte M24hr = 2;
//Clocks
const byte clock0 = 0;
const byte alarm1 = 1;
const byte alarm2 = 2;
const byte RTC_addr = 0x68;    // I2C address of DS3231 RTC
const byte EEPROM_addr = 0x57; // I2C address of AT24C32N EEPROM
const bool INTCN = true;       // allows SQW pin to be monitored
bool blinkdots = true;
unsigned long CurrentMillis;
unsigned long PreviousMillis;
byte ClockState;
int Hour, Min, Sec, DOW, DAY, Month, Year, Clockmode;
DateTime NowTime; //create DateTime struct from Library
DS3231RTC Clock(RTC_addr, EEPROM_addr, INTCN);
ezButton Button_Set_Pin(3); // Button for display Menu and set // Snooze Pin
ezButton Button_Inc_Pin(4); // Button for incrementing Value
ezButton Button_Dec_Pin(5); // Button for decrementing Value
void GetTime()
        NowTime = Clock.read(); // get the latest clock values
        Sec = NowTime.Second;
        Min = NowTime.Minute;
        Hour = NowTime.Hour;
        DOW = NowTime.Dow; //  Day of Week
        DAY = NowTime.Day;
        Month = NowTime.Month;
        Year = NowTime.Year;
        Clockmode = NowTime.ClockMode;
        Serial.print("Current Time is ");
        Serial.print(Hour);
        Serial.print(":");
        Serial.print(Min);
        Serial.print(":");
        Serial.println(Sec);
        Serial.print("Today's Date is ");
        Serial.print(p2Digits(DAY));
        Serial.print("/");
        Serial.print(p2Digits(Month));
        Serial.print("/");
        Serial.println(Year);
        Serial.print("Today's Day is ");
        Serial.println(dow2Str(DOW));
        Serial.print("Clock mode is ");
        Serial.println(Clockmode); */
void TimeDisplay()
        blinkdots = !blinkdots;
        MaxDisplay(3, (Hour / 10) + 48, 3);
        MaxDisplay(2, (Hour % 10) + 48, 1);
        MaxDisplay(1, (Min / 10) + 48, 2);
        MaxDisplay(0, (Min % 10) + 48, 0);
void MaxDisplay(byte address, byte character, byte offset)
        if (character >= 0x20 && character <= 0x7f)
                for (int a = 0; a < 7; a++)
                        unsigned long c = pgm_read_byte_near(font5x7 + ((character - 0x20) * 8) + a);
                        unsigned long x = c >> offset;
                        lc.setRow(address, a, x); //setRow(int addr, int row, byte value)
                        if (address == 2)
                                if (a == 1)
                                        lc.setLed(2, 1, 7, blinkdots); //setLed(int addr, int row, int column, boolean state)
                                if (a == 2)
                                        lc.setLed(2, 2, 7, blinkdots);
                                if (a == 5)
                                        lc.setLed(2, 5, 7, blinkdots);
                                if (a == 6)
                                        lc.setLed(2, 6, 7, blinkdots);
                        if (address == 1)
                                if (a == 1)
                                        lc.setLed(1, 1, 0, blinkdots); //setLed(int addr, int row, int column, boolean state)
                                if (a == 2)
                                        lc.setLed(1, 2, 0, blinkdots);
                                if (a == 5)
                                        lc.setLed(1, 5, 0, blinkdots);
                                if (a == 6)
                                        lc.setLed(1, 6, 0, blinkdots);
void ChangeMinute(byte i = 0, bool increment = true)
        /*  Increments or decrements the minute by one
     *    i = 0 Clock
     *      = 1 Alarm1
     *      = 2 Alarm2
        if (increment == true)
                Min++;
                if (Min > 59)
                        Min = 0;
                Min--;
                if (Min < 0)
                        Min = 59;
        Clock.ChangeMin(Min);
void ChangeHour(byte i = clock0, bool increment = true)
        switch (Clockmode)
        case AMhr:
        case PMhr:
                        Hour++;
                        if (Hour > 12)
                                Hour = 0;
                        Hour--;
                        if (Hour < 0)
                                Hour = 12;
        case M24hr:
                        Hour++;
                        if (Hour > 24)
                                Hour = 0;
                        Hour--;
                        if (Hour < 0)
                                Hour = 23;
        Clock.ChangeHour(Clockmode, Hour);
void ChangeClockMode(byte i = clock0, bool increment = true)
        /*  Change Clock's Clockmode to AM=0, PM=1 or 24=2
     *  Limited change of Alarm's Clockmode to AM or PM
     *  or no change if 24hr
     *    i = 0 Clock0
     *      = 1 Alarm1
     *      = 2 Alarm2
        switch (i)
        case clock0:
                        Clockmode += 1;
                        Clockmode %= 3;
                        Clockmode -= 1;
                        Clockmode %= 3;
                if (Clockmode < 0)
                        Clockmode = 2;
                //byte(Clockmode);
                Clock.ChangeHour(byte(Clockmode), Hour);
void ChangeDate(byte i = 0, bool increment = true)
        byte DaysMax = 31;
        switch (Month)
        case 1:
        case 3:
        case 5:
        case 7:
        case 8:
        case 10:
        case 12:
                DaysMax = 31;
        case 2:
                DaysMax = 28;
                if ((Year % 4 == 0) && (Year % 100 != 0) || (Year % 400 == 0))
                        //those are the conditions to have a leap year
                        DaysMax = 29;
        case 4:
        case 6:
        case 9:
        case 11:
                DaysMax = 30;
        default:
                DAY += 1;
        if (increment == false)
                DAY -= 1;
        if (DAY < 1)
                DAY = DaysMax;
        if (DAY > DaysMax)
                DAY = 1;
        Clock.ChangeDate(byte(DAY));
void ChangeMonth(byte i = 0, bool increment = true)
                Month++;
                if (Month > 12)
                        Month = 0;
                Month--;
                if (Month < 0)
                        Month = 12;
        Clock.ChangeMonth(Month);
String dow2Str(byte bDow)
        // Day of week to string or char array. DOW 1=Sunday, 0 is undefined
        static const char *str[] = {"---", "Sun", "Mon", "Tue", "Wed", "Thu", "Fri", "Sat"};
        if (bDow > 7)
                bDow = 0;
        return (str[bDow]);
String p2Digits(int numValue)
        // utility function for digital clock display
        // converts int to two digit char array
        String str;
        if (numValue < 10)
                str = "0" + String(numValue);
                str = String(numValue);
        return str;
        Button_Set_Pin.setDebounceTime(100); // set debounce time to 50 milliseconds
        Button_Inc_Pin.setDebounceTime(100); // set debounce time to 50 milliseconds
        Button_Dec_Pin.setDebounceTime(100); // set debounce time to 50 milliseconds
        Clock.begin();
        for (int i = 0; i < devices; i++)
                lc.shutdown(i, false);
                lc.setIntensity(i, bright); //set light intensity 0 - min, 15 - max
                lc.clearDisplay(i);         //Clear Display
        Button_Set_Pin.loop();
        Button_Inc_Pin.loop();
        Button_Dec_Pin.loop();
        /*     if (Button_Set_Pin.isPressed())
                Serial.println("The Menu button is pressed");
        if (Button_Set_Pin.isReleased())
                Serial.println("The Menu button is released");
        if (Button_Inc_Pin.isPressed())
                Serial.println("The Increment button is pressed");
        if (Button_Inc_Pin.isReleased())
                Serial.println("The Increment button is released");
        if (Button_Dec_Pin.isPressed())
                Serial.println("The Decrement button is pressed");
        if (Button_Dec_Pin.isReleased())
                Serial.println("The Decrement button is released");
        switch (ClockState)
        case 0:
                CurrentMillis = millis();
                if (CurrentMillis - PreviousMillis >= 500)
                        PreviousMillis = CurrentMillis;
                        GetTime();
                        TimeDisplay();
                        ClockState = 1;
        case 1:
                // For Change Hour
                MaxDisplay(1, 32, 2); // for printing Space on screen
                MaxDisplay(0, 72, 0); // For printing 'H' on screen
                        ChangeHour(clock0, true);
                        ChangeHour(clock0, false);
                        ClockState = 2;
        case 2:
                // For Change Minutes
                MaxDisplay(3, 77, 3);
                MaxDisplay(2, 32, 1);
                        ChangeMinute(clock0, true);
                        ChangeMinute(clock0, false);
                        ClockState = 3;
        case 3:
                // For Change Brightness
                MaxDisplay(3, 66, 3);
                MaxDisplay(1, (bright / 10) + 48, 2);
                MaxDisplay(0, (bright % 10) + 48, 0);
                        bright++;
                        if (bright > 15)
                                bright = 0;
                        bright--;
                        if (bright < 0)
                                bright = 15;
                        ClockState = 4;
        case 4: // Set Date
                MaxDisplay(3, 68, 3);
                MaxDisplay(2, 68, 1);
                MaxDisplay(1, (DAY / 10) + 48, 2);
                MaxDisplay(0, (DAY % 10) + 48, 0);
                        ChangeDate(clock0, true);
                        ChangeDate(clock0, false);
                        ClockState = 5;
        case 5: // Set Month
                MaxDisplay(2, 77, 1);
                MaxDisplay(1, (Month / 10) + 48, 2);
                MaxDisplay(0, (Month % 10) + 48, 0);
                        ChangeMonth(clock0, true);
                        ChangeMonth(clock0, false);
                        ClockState = 6;
        case 6: // Set Year
                MaxDisplay(3, 89, 3);
                MaxDisplay(2, 89, 1);
                MaxDisplay(1, (Year / 10) + 48, 2);
                MaxDisplay(0, (Year % 10) + 48, 0);
                        Year++;
                        if (Year > 50)
                                Year = 0;
                        Year--;
                        if (Year < 0)
                                Year = 50;
                        ClockState = 7;
        case 7:
                //  For Change Clock Mode
                /*      Clock Modes
        AM Mode         0
        PM Mode         1
        24 Hour Mode    2 */
                MaxDisplay(3, 67, 3);
                if (Clockmode == 0) // For print 12hr/AM Format
                        MaxDisplay(1, 65, 2); // A
                        MaxDisplay(0, 77, 0); // M
                if (Clockmode == 1) // For print 12hr/AM Format
                        MaxDisplay(1, 80, 2); // P
                if (Clockmode == 2) // For print 24hr Format
                        MaxDisplay(1, 2 + 48, 2);
                        MaxDisplay(0, 4 + 48, 0);
                        ChangeClockMode(clock0, true);
                        ChangeClockMode(clock0, false);
                        ClockState = 0;
                // do something
You seem to have three button switches. Is one button causing the problem, or are all three doing the same thing? How do you have them wired? A block diagram showing the Arduino, the switches and the power connections would be enough.
Paul
Thanks for reply. Yes i am using three buttons.
1 for Menu button
2nd for Incrementing Values.
3rd for decrementing values.
all buttons causing problems.
I will create diagram first and upload it soon.
there's a lot of non button related code to look thru.
you could try writing a separate program that simply exercises the use of the button library library you're using to make sure it behaves the way you expect.
is there a distinction between "isPressed" as in being held down and "pressed" indicating a button has changed state and is current held down, a single event?
Not Understand ... Should i change button library ?
