Facing Gurumeditation error: Store prohibited
#include <WiFi.h>
#include <BLEDevice.h>
#include <BLEScan.h>
#include <time.h>
#include <Firebase_ESP_Client.h>
#include "addons/TokenHelper.h"   // This file already defines tokenStatusCallback.
#include "addons/RTDBHelper.h"
#include <vector>
#include <map>
using namespace std;
#define WIFI_SSID      "*****"
#define WIFI_PASSWORD  "******"
// cred
#define API_KEY        "*********"
#define DATABASE_URL   "********"
// RSSI
#define RSSI_THRESHOLD -90
// ntp settings
const char* ntpServer = "time.google.com";
const long gmtOffset_sec = 19800;
const int daylightOffset_sec = 0;
// ble objects
BLEScan* pBLEScan;
// rtc var
time_t rtcStartTime = 0;  // Changed to time_t (64-bit)
//unsigned long rtcStartTime = 0;
unsigned long systemStartMillis = 0;
bool rtcSynced = false;
// tag data struct
struct TagData {
  String mac;
  String inTime;
  String outTime;
  unsigned long lastSeen;
vector<TagData> tagBuffer;
//firebase objects
FirebaseData fbdo;
FirebaseAuth auth;
FirebaseConfig config;
// Use std::map explicitly to avoid conflict with Arduino's built-in map() function.
std::map<String, int> sessionSequence;
bool connectToWiFi();
bool initializeRTC();
String getFormattedRTCTime();
String getFormattedDate();
int getCurrentHour();
String getFirebasePath(const String &mac, int sequence);
void pushTagData(const TagData &tag);
void pushAllTagData();
void checkForTagTimeouts();
// wifi con
bool connectToWiFi() {
  // If already connected, nothing to do
  if (WiFi.status() == WL_CONNECTED) return true;
  Serial.println("Attempting to connect to WiFi...");
  WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
  unsigned long startAttemptTime = millis();
  while (WiFi.status() != WL_CONNECTED && millis() - startAttemptTime < 10000) {
    Serial.print(".");
  if (WiFi.status() == WL_CONNECTED) {
    Serial.println("\nConnected to Wifi");
    return true;
    Serial.println("\nFailed to connect to Wifi");
    return false;
// rtc init
bool initializeRTC() {
  configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
  struct tm timeinfo;
  for (int i = 0; i < 5; i++) {
    if (getLocalTime(&timeinfo)) {
      rtcStartTime = time(nullptr);  // Store as 64-bit time_t
      systemStartMillis = millis();
      rtcSynced = true;
      Serial.print("RTC Synced: ");
      Serial.println(ctime(&rtcStartTime));  // Correct print
      return true;
    Serial.println("Retrying RTC sync");
    delay(2000);
  rtcSynced = false;
  Serial.println("Failed to sync RTC.");
  return false;
String getFormattedRTCTime() {
  struct tm timeinfo;
  time_t now = rtcStartTime + (millis() - systemStartMillis) / 1000;
  if (localtime_r(&now, &timeinfo)) {
    char timeString[9];
    strftime(timeString, sizeof(timeString), "%H:%M:%S", &timeinfo);
    return String(timeString);
  return "00:00:00";
String getFormattedDate() {
  time_t now = time(nullptr);
  struct tm timeinfo;
    char dateStr[11]; // "YYYY-MM-DD"
    strftime(dateStr, sizeof(dateStr), "%Y-%m-%d", &timeinfo);
    return String(dateStr);
  return "0000-00-00";
int getCurrentHour() {
  struct tm timeinfo;
    return timeinfo.tm_hour;
  return 0;
String getFirebasePath(const String &mac, int sequence) {
  String date = getFormattedDate();
  int hour = getCurrentHour();
  String period = (hour < 10) ? "morning" : "afternoon_evening";
  String path = "/tags/" + mac + "/" + date + "/" + period + "/" + String(sequence);
  return path;
//push data firebase
void pushTagData(const TagData &tag) {
  if (WiFi.status() != WL_CONNECTED) {
    Serial.println("WiFi not connected. Data push skipped for tag: " + tag.mac);
    return;
  // Ensure Firebase is authenticated
  if (!Firebase.ready()) {
    Serial.println("Firebase not ready. Trying to refresh token...");
    Firebase.refreshToken(&config);
    delay(1000);  // Give some time to refresh
      Serial.println("Firebase still not ready. Skipping push.");
      return;
  FirebaseJson json;
  json.set("mac", tag.mac);
  json.set("inTime", tag.inTime);
  json.set("outTime", tag.outTime);
  json.set("lastSeen", tag.lastSeen);
  String key = tag.mac + "_" + getFormattedDate();
  int seq = 1;
  if (sessionSequence.find(key) != sessionSequence.end()) {
    seq = sessionSequence[key] + 1;
  sessionSequence[key] = seq;
  String path = getFirebasePath(tag.mac, seq);
  // Clear FirebaseData object before each use
  fbdo.clear();
  if (Firebase.RTDB.setJSON(&fbdo, path.c_str(), &json)) {
    Serial.println("Firebase push success for tag: " + tag.mac + " at path: " + path);
    Serial.println("Firebase push failed for tag " + tag.mac + ": " + fbdo.errorReason());
    // If error is due to authentication, refresh token and retry once
    if (fbdo.errorReason().indexOf("token is not ready") >= 0) {
      Serial.println("Refreshing Firebase token...");
        Serial.println("Firebase push retry successful for tag: " + tag.mac);
        Serial.println("Firebase push failed again: " + fbdo.errorReason());
// Iterate over tagBuffer, finalize each session and push the data.
void pushAllTagData() {
    Serial.println("Wifi not connected. Cannot push.");
    return;
  for (auto &tag : tagBuffer) {
    if (tag.outTime == "") {
      tag.outTime = getFormattedRTCTime();
      Serial.println("Setting outTime for tag " + tag.mac + " as " + tag.outTime);
    pushTagData(tag);
  tagBuffer.clear();
void checkForTagTimeouts() {
    if (tag.outTime == "" && (currentMillis - tag.lastSeen) > 60000) { // 60 sec timeout
      Serial.println("Tag timeout: " + tag.mac + ", OutTime: " + tag.outTime);
// BLE Advertised Device Callback
class MyAdvertisedDeviceCallbacks : public BLEAdvertisedDeviceCallbacks {
  void onResult(BLEAdvertisedDevice advertisedDevice) {
    if (!rtcSynced) {
      Serial.println("Skipping ble scan due to rtc sync failure.");
      return;
    int rssi = advertisedDevice.getRSSI();
    String mac = advertisedDevice.getAddress().toString().c_str();
    String name = advertisedDevice.getName().c_str();
    // Filter for devices whose name starts with "ZT" and meet the RSSI threshold.
    if (name.startsWith("ZT") && rssi >= RSSI_THRESHOLD) {
      bool activeSessionFound = false;
        if (tag.mac == mac && tag.outTime == "") {  // active session exists
          tag.lastSeen = millis();
          activeSessionFound = true;
      if (!activeSessionFound) {
        TagData newTag = { mac, getFormattedRTCTime(), "", millis() };
        tagBuffer.push_back(newTag);
        Serial.println("New session started for tag: " + mac + ", InTime: " + newTag.inTime);
  connectToWiFi();
  initializeRTC(); // Sync RTC once
  config.api_key = API_KEY;
  config.database_url = DATABASE_URL;
  auth.user.email = "******";
  auth.user.password = "*******";
  Firebase.reconnectWiFi(true);
  Firebase.begin(&config, &auth);
  // Wait for Firebase connection
  Serial.print("Connecting to Firebase");
  unsigned long start = millis();
  while (!Firebase.ready() && millis() - start < 15000) {
    Serial.print(".");
  if (Firebase.ready()) {
    Serial.println("\nFirebase ready!");
    Serial.println("\nFailed to connect to Firebase.");
  BLEDevice::init("");
  pBLEScan = BLEDevice::getScan();
  pBLEScan->setAdvertisedDeviceCallbacks(new MyAdvertisedDeviceCallbacks());
  pBLEScan->setActiveScan(true);
    Serial.println("WiFi not connected. Attempting to reconnect...");
    connectToWiFi();
      // Sync RTC only if it wasn't synced before
      if (!rtcSynced) {
        initializeRTC();
    // Check Firebase connection before pushing data
      Serial.println("Firebase not ready, reconnecting");
      Serial.println("wifi conn. push data to firebase.");
      pushAllTagData();
      Serial.println("firebase conn failed.");
    delay(10000);
    Serial.println("wifi not connected. Scanning ble");
    pBLEScan->start(30, false);
    delay(5000);
Use the stack trace decoder to find out more about what’s going on and triggered the issue
