Facing problem while burning bootloader on ATmega328
Hi, i am trying to flash boot-loader on ATmega328 using Arduino Nano. I have done the connection as follows Arduino Pin 13 -> chip pin 19. Arduino Pin 12 -> chip pin 18. Arduino Pin 11 -> chip pin 17. Arduino Pin 10 -> chip pin 1 Reset
i m using 8MHz crystal and 22pf capacitor connected on pin 9 and 10.
Here part of boards.txt file i have added.
uno328.name=Arduino328
uno328.upload.protocol=arduino
uno328.upload.maximum_size=32256
uno328.upload.speed=57600
uno328.bootloader.low_fuses=0xff
uno328.bootloader.high_fuses=0xde
uno328.bootloader.extended_fuses=0x05
uno328.bootloader.path=optiboot
uno328.bootloader.file=ATmegaBOOT_168_atmega328_pro_8MHz.hex
uno328.bootloader.unlock_bits=0x3F
uno328.bootloader.lock_bits=0x0F
uno328.bootloader.tool=arduino:avrdude
uno328.build.mcu=atmega328
uno328.build.f_cpu=8000000L
uno328.build.core=arduino
uno328.build.variant=standard
atmega328bb.name=ATmega328(8 MHz internal clock)
atmega328bb.upload.protocol=arduino
atmega328bb.upload.maximum_size=30720
atmega328bb.upload.speed=57600
atmega328bb.bootloader.low_fuses=0xE2
atmega328bb.bootloader.high_fuses=0xDA
atmega328bb.bootloader.extended_fuses=0x05
atmega328bb.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
atmega328bb.bootloader.unlock_bits=0x3F
atmega328bb.bootloader.lock_bits=0x0F
atmega328bb.build.mcu=atmega328p
atmega328bb.build.f_cpu=8000000L
atmega328bb.build.core=arduino:arduino
atmega328bb.build.variant=arduino:standard
atmega328bb.bootloader.tool=arduino:avrdude
atmega328bb.upload.tool=arduino:avrdude
Both configuration is not working.
I am getting following error after trying to flash bootloader.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x15
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x01
avrdude: stk500_initialize(): (a) protocol error, expect=0x14, resp=0x10
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude: stk500_disable(): unknown response=0x12
Error while burning bootloader.
Connected 10uf capacitor between VCC and GND also. And my arduino ide version is 1.8.8.
Any help will be appreciated...
Connect 10uF capacitor between Reset and GND on the Nano after you load the "ArduinoasISP' sketch.
I recommend using Minicore. Works great and gives you many options.
https://github.com/MCUdude/MiniCore
