Fade 6 LED's w PWM
A short program for fading 6 LED's (w Atemega168).
Demonstrates use of arrays
/* Fade6LEDs
Paul Badger 2007
Program to fade 6 LED's up and down.
Demonstates using arrays
int i; // counter variable
float LED[] = {0,0,0,0,0,0}; // pwm brightness variables
float spChg[] = {.8, 2.75, .21, .61, .49, .99}; // speeds to fade LED's - change these for faster or slower fades
int pwmPins[] = {3,5,6,9,10,11}; // PWM pins - 3,5,6 won't work on Atmega8
int ud[]={1,1,1,1,1,1}; // up - down multiplier
for (i=0; i<=5; i++){
if (LED > 255){
_ ud = -1;_
_ else if(LED < 1){
ud = 1;
LED = LED + (spChg * ud*);*
analogWrite(pwmPins, (int)LED*);
}*_
/* Fade6LEDExpon
Paul Badger 2007
Program to fade 6 LED's up and down, with an exponential curve
This one looks more organic than the arithmetic version
float LED[] = {1,1,1,1,1,1}; // pwm brightness variables
float spChg[] = {1.04, 1.05, 1.06, 1.07, 1.03, 1.003}; // speed varialbes to fade LED's - change these for faster or slower fades
// values should be close to and greater than 1
if (LED > 255){
_ ud = -1;_
_ else if(LED < 1){
ud = 1;
_
_ if (ud == 1){ // up flag, multiply spChg variable
LED = LED * spChg*; // multiply by a fixed amount - spCh array controls the speed of fade*
else*
* { // down flay, divide spChg variable*
LED = LED / spChg*;*
* }*_
analogWrite(pwmPins_, (int)LED*);
delay(1); // this will interact with the spChg variables to control ultimate fade speed*
}*_
