I have an ESC connected to a pwm pin and i am using servo.h library.
The ESC input is controlled by a potentiometer. Now the ESC gets the value set up on the poti immediatley, but i want the ESC to get the changed signal of the poti with a fade, so that the signal generated by the poti and sent to the ESC ramps up in a specific time (up to the value that is defined by the current poti signal value).
I didnt find anything on the internet, maybe one of you know what kind of code snippet i can use?
What's the current code?
Don't forget to take advantage of the IDE's auto-format and copy to forums feature.
The idea is that instead of outputting the POT value directly to the PWM, It will use the POT value as the target value, manage the PWM output value separately, and gradually increase or decrease it toward the target value.
I have to add that i want to achieve this "fade" every time the signal from the poti is changed, not only once, so that every change of speed (signal to ESC) is smooth and not abrupt. So this needs to work with increasing as also decreasing values.
#include <Servo.h>
Servo ESC; // create servo object to control the ESC
int pot1Value; // value from the analog pin
// Attach the ESC1 on pin 9, ESC2 on pin 10
ESC.attach(9,1000,2000); // (pin, min pulse width, max pulse width in microseconds)
pot1Value = analogRead(A0); // reads the value of the potentiometer (value between 0 and 1023)
pot1Value = map(pot1Value, 0, 1023, 0, 180); // scale it to set max speed
ESC.write(pot1Value); // Send the signal of potvalue1 to ESC1
The input is your potentiometer value, the output will be the value to send to the ESC which will eventually get to the input signal at a rate determined by the constants you can adjust.
I don’t know if you meant to ask or imply, but the ESC will not know about any of this, it just responds to the calculated value it is sent.
Using servo.writeMicroseconds() (range: 1000 to 2000) instead of servo.write() (range: 0 to 180) you get more, and therefore smoother, control steps.
Using micros() for timing instead of a loop counter you get more accurate timing control and get to directly control the slew rate (how fast the control signal changes). I set it for 25% of full scale per second. That's four seconds from 0 to full speed. Pick a value from 1% (100 seconds full scale) to over 200% (half a second full scale).
#include <Servo.h>
const byte ESC1Pin = 9;
const byte Pot1Pin = A0;
const unsigned SlewRate = 25; // percent full scale per second
const unsigned long MicrosecondsFullScale = 100000000UL / SlewRate;
const unsigned StepsFullScale = 2000 - 1000; // Range is 1000 to 2000 microseconds
const unsigned long MicrosecondsPerStep = MicrosecondsFullScale / StepsFullScale;
Servo ESC1;
ESC1.attach(ESC1Pin, 1000, 2000);
static unsigned long LastMoveTime = 0;
static unsigned int esc1Value = 0;
unsigned long currentMicros = micros();
unsigned int pot1Value = map(analogRead(Pot1Pin), 0, 1023, 1000, 2000);
if (currentMicros - LastMoveTime > MicrosecondsPerStep)
LastMoveTime = currentMicros;
if (esc1Value > pot1Value) esc1Value--;
if (esc1Value < pot1Value) esc1Value++;
ESC1.writeMicroseconds(esc1Value);
