fade down, STOP. fade up, STOP.
some analog sensor pin i have. I'm actually having a bit of trouble, and I'm not sure if you can check this code out. as the code illustrates, i want to do what your previous code does, except amongst 3 leds. so as you go up sensor reading, the previous led fades, and the next fades up. heres what i have but the problem is the sensor reading is pausing and two led's are staying on and its very jerky. let me know what you'd suggest.
boolean compare = true;
const int pingPin = 7;
 int avRead;
int ledPin = 9;
int ledPin2 = 10;
int ledPin3 = 11;
// LED connected to digital pin 9
int fadeValue;
void setup()  {
  Serial.begin(9600); // nothing happens in setup
   pinMode (ledPin, OUTPUT);
   pinMode (ledPin2, OUTPUT);
  pinMode (ledPin3, OUTPUT); // ADD THIS
void loop()  {
  long duration, inches, cm;
  // The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
  // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  // The same pin is used to read the signal from the PING))): a HIGH
  // pulse whose duration is the time (in microseconds) from the sending
  // of the ping to the reception of its echo off of an object.
  pinMode(pingPin, INPUT);
  duration = pulseIn(pingPin, HIGH);
  // convert the time into a distance
  inches = microsecondsToInches(duration);
  cm = microsecondsToCentimeters(duration);
  Serial.print(inches);
  Serial.print("in, ");
  Serial.print(cm);
  Serial.print("cm");
  delay(100);
  avRead = cm;
  if(avRead == 12 && compare == true){ // fade up if avRead is >15 and fade down has run
    for (int fadeValue = 0 ; fadeValue <= 255; fadeValue +=5) {
      analogWrite(ledPin, fadeValue);
      delay(20);
    compare = false;  // set compare for fade down when avRead goes 15 or lower next pass thru loop
  if (avRead>=5 && compare == false ){
    for (int fadeValue = 255 ; fadeValue >= 0; fadeValue -=5) {
      delay(20);
    compare = true;
      analogWrite(ledPin2, fadeValue);
      delay(20);
  if (avRead>=20 && compare == false ){
      delay(20);
    compare = true;
 if(avRead == 27 && compare == true){ // fade up if avRead is >15 and fade down has run
      analogWrite(ledPin3, fadeValue);
      delay(20);
  if (avRead>=36 && compare == false ){
      delay(20);
    compare = true;
long microsecondsToInches(long microseconds)
  // According to Parallax's datasheet for the PING))), there are
  // 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
  // second).  This gives the distance travelled by the ping, outbound
  // and return, so we divide by 2 to get the distance of the obstacle.
  // See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
  return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
  // The speed of sound is 340 m/s or 29 microseconds per centimeter.
  // The ping travels out and back, so to find the distance of the
  // object we take half of the distance travelled.
  return microseconds / 29 / 2;
Maybe you should change these to >= vs ==
Having to hit a specific number is hard
or make them a range:
( ( avRead >=12 && avRead<20 ) && compare == true )
( ( avRead >=27 && avRead<36 ) && compare == true )
that kind of idea
Post what you have - got to be a slight syntax error.
