Fade in and out an LED sketch inside a larger program slows the program down
I wrote a sketch for a self leveling sissor table with a calibration button. The button is one that has a nice red ring around it that is lit by an LED. I got my hands on some code that will fade in and fade out the led to make it look cool ( like on a mac computer). When I input that LED code into my sketch it slows the entire program down to the dimming speed.
How can I separate the speeds/sketches so that they can both operate off of an arduino uno?
I know I have to put the LED in the set up and so on…
The following is my table sketch:
int groundpin = 18;
int powerpin = 19;
int xpin = 3;
int ypin = 2;
int zpin = 1;
#define BUTTON 7
int val = 0;
int relay1 = 11;
int relay2 = 10;
long y = 0;
long a = 0;
void setup(){
  pinMode(BUTTON, INPUT);
  pinMode(relay1, OUTPUT);
  pinMode(relay2, OUTPUT);
  pinMode(groundpin, OUTPUT);
  pinMode(powerpin, OUTPUT);
  digitalWrite(groundpin, LOW);
  digitalWrite(powerpin, HIGH);
  a = analogRead (ypin);
  Serial.println (analogRead(ypin));
  delay(10);
  val = digitalRead(BUTTON);
 if (val == HIGH) {
          Serial.print("y = ");
          y = analogRead(ypin);
          //delay (25);
 if (a > (y + 6)) {
         digitalWrite(relay1, HIGH);
         Serial.print (y);
         Serial.println("---The Table Is Off Level--- 1");
         delay (500);
  digitalWrite(relay1, LOW);
  if (a < (y - 6)) {
         digitalWrite(relay2, HIGH);
         Serial.print (y);
         Serial.println("---The Table Is Off Level--- 2");
         delay (500);
  } else  {
  digitalWrite(relay2, LOW);
Here is the dimming code:
#define LED 9
int i = 0;
void setup(){
  pinMode(LED, OUTPUT);
  for (i = 0; i < 255; i++) {
  analogWrite(LED, i);
  delay(15);
for (i = 255; i > 0; i--) {
  delay(15);
Any suggestions would be appreciated!
Rewrite your code to not use delay(). Read up on the BlinkWithoutDelay example in the playground.
http://wikibox.stanford.edu/12-13/index.php/Assignments/BasicArduinoMultiTaskTutorial
