Fade LED up and down with signal
Hi ! First post here so hope i get this right.
Here is my problem :
I want to use a TIP120 transistor to turn on and of a 12v led with the arduino. Simple. But then i want a 0 signal to start to fade up the LED light and when the arduino get 1 signal again i want it to fade the LED down and turn it of.
Another problem is the delay, cant use that in my program.
So need a code to start the fading up when the arduino input is low. When the light is faded up max it will stay there until the arduino get a 1 signal, then start to fade down and turn it of at the end
I want the fading up and down to be on ca 10 sec or something.
Can someone help me with this ?
The IDE includes an example called "blink without delay" which shows how to manage timing tasks without using delay.
Yeah, i know, but i cant understand how the " blink without delay" can work with this problem... Could you maybe write me an eksample code? Would be wery helpfull.
Instead of thinking of it as "blink" (ie, simply flip a bit), think of it as "signal an event", like " increase the brightness of my LED"
Okei, i think i understand what you mean. But i also struggle to make a code to dim the light. I made a code to dim it up and down, but i had problem to get the led lighting max between dim up and down. If you understand?
