Hi
i want to make a simple application: turn on/off a fading led using IR remote. I am using IRremote library (A Multi-Protocol Infrared Remote Library for the Arduino
And my code just doesnt work.. It turns on when i first press the button, but doesnt react on next signals. Just dont know what to do..
here is the main part
if (irrecv.decode(&results))
if (results.value==52160) { //it is the value remote button i use
if(sw==1) sw=0;
else sw=1;
irrecv.resume();
if(sw==1) fade(); //fade led
if(sw==0) zero(); // turn led off
Okay, actually the task is a little more complicated, i want ot turn on/off RGB lamp which is changing colours in random sequence
when i press "on" button it starts changing colours, but doesn't turn off when i press the button again
#include <IRremote.h>
#include <Metro.h>
const int irReceivePin =2;
Metro ledMetro = Metro(10) ;
Metro irmetro = Metro(500);
IRrecv irrecv(irReceivePin);
decode_results results;
int prevKey, prevKey2;
float RGB1[3];
float RGB2[3];
float INC[3];
int sw;
int fadeAmount = 5;
int brightness = 0;
int red, green, blue;
int RedPin = 3;
int GreenPin = 5;
int BluePin = 6;
{ Serial.begin(9600);
pinMode(irReceivePin, INPUT);
irrecv.enableIRIn();
randomSeed(analogRead(0));
RGB1[0] = 0;
RGB1[1] = 0;
RGB1[2] = 0;
RGB2[0] = random(256);
RGB2[1] = random(256);
RGB2[2] = random(256);
if(sw==1) lamp();
if(sw==0) zero();
{Serial.println(results.value);
if(sw==1) sw=0;
else sw=1;
irrecv.resume();
void lamp() {
for (int x=0; x<3; x++) {
INC[x] = (RGB1[x] - RGB2[x]) / 256; }
for (int x=0; x<256; x++) {
if (ledMetro.check() == 1) {
red = int(RGB1[0]);
green = int(RGB1[1]);
blue = int(RGB1[2]);
analogWrite (RedPin, red);
analogWrite (GreenPin, green);
analogWrite (BluePin, blue);
RGB1[0] -= INC[0];
RGB1[1] -= INC[1];
RGB1[2] -= INC[2];
label:
RGB2[x] = random(556)-300;
RGB2[x] = constrain(RGB2[x], 0, 255);
if(RGB2[0]==0 && RGB2[1]==0 && RGB2[2]==0) goto label;
void zero() {
analogWrite (RedPin, 0);
analogWrite (GreenPin, 0);
analogWrite (BluePin, 0);
Println results: first line is number of ir button, and then always "0", and nothing when i push the button
OK I may be wrong here but are you using a digital pin (2) to recieve the IR , also how exactly have you done the hardware, as far as im aware IR codes are HEX data so they must use a serial input, are you revieving using a IR photo diode, if so im sure that the digital in pin will not suffice for this application.
Are you able to get better results with the examples/IRrecvDemo sketch? According to the link you provided, you may need to tweak the library to accommodate the protocol for your particular remote device.
Also, I didn't dig through lamp() in any detail, but you can certainly replace that goto with a do while.
Oops yeah just actually read the link, so yeah its for a digital string, anyway still would use the com prt for serial, anyway check out, http://www.remotecentral.com/ for some actuall raw binarys of the codes!!
Add a Serial.print() statement to show when lamp() is entered, and when it ends. There are a lot of hidden delays going on there. When lamp() is executing, you are not reading IR data.
Is it possible to make program read IR data and run a lamp() program simultaneously? I want to be able to turn the fading lamp off when the fading program is running?
What is the trick?
#include <boarddefs.h> #include <IRremote.h>
const int receiver = 3; // pin 1 of IR receiver to Arduino digital pin 11
const int ledPin = 9;
int Led = 12;
int fadeValue;
int lastCounter = 1;
int counter;
IRrecv irrecv(receiver); // create instance of 'irrecv'
