Hi Guys!
Im kind of new to Arduino as a webserver. I have made the simple tutorials, as turning a LED on/off. All of it is working fine.
But i want to made a LED fade up and down continuously if i push i button in the browser. Here is my problem. When i push the button the LED turns on, and steps up very slow. It appears to do one step every time the site refreshes (5 secs)
How do i do it??
#include <WebServer.h>
#include <SPI.h>
#include <Ethernet.h>
// ethernet configuration
byte mac[] = { 0xAA, 0xBB, 0xCC, 0xDD, 0xEE, 0xFF };
byte ip[] = { 192, 168, 1, 111 }; // P1 --> { 10, 1, 1, 5 };
EthernetServer server(80); // port 80 is default for HTTP
// initial
int LED = 3; // led is connected to digital pin 3
int brightness = 0; // how bright the LED is
int fadeAmount = 5; // how many points to fade the LED by
int LDR = 5; // LDR sensor is connected to analog in 5
float photocell = 0; // variable for photocell (LDR) analog value
char c = 0; // received data
char command[2] = "\0"; // command
Ethernet.begin(mac, ip);
server.begin();
pinMode(LED, OUTPUT);
// detect if current is the first line
boolean current_line_is_first = true;
if (client) {
// an http request ends with a blank line
boolean current_line_is_blank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
// if we've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so we can send a reply
if (c == '\n' && current_line_is_blank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println();
// auto reload webpage every 5 second
client.println("<META HTTP-EQUIV=REFRESH CONTENT=5 URL=>");
// webpage title
client.println("<center><p><h1>LoveHeart <3</h1></p><center><hr>
// read analog pin 1 for the value of photocell
photocell = analogRead(LDR);
client.print("<p><h2>Light reading = <font color=indigo>");
client.println(photocell, 2);
client.println("</font></h2></p>");
// read digital pin 13 for the state of PIR sensor
// button functions
client.println("<form method=get name=form>");
client.println("<button name=b value=1 type=submit style=height:80px;width:150px>LED On</button>");
client.println("<button name=b value=2 type=submit style=height:80px;width:150px>LED Off</button>");
client.println("</form>
// webpage footer
client.println("<hr><center>LoveHeart by kucza
client.println("<p>P.S.: This page will automatically refresh every 5 seconds.</p></center>");
if (c == '\n') {
// we're starting a new line
current_line_is_first = false;
else if (c != '\r') {
// we've gotten a character on the current line
current_line_is_blank = false;
// get the first http request
if (current_line_is_first && c == '=') {
for (int i = 0; i < 1; i++) {
c = client.read();
command[i] = c;
// LED control
if (!strcmp(command, "1")) {
fade();
else if (!strcmp(command, "2")) {
digitalWrite(LED, LOW);
// give the web browser time to receive the data
delay(1);
client.stop();
void fade() {
analogWrite(LED, brightness);
// change the brightness for next time through the loop:
brightness = brightness + fadeAmount;
// reverse the direction of the fading at the ends of the fade:
if (brightness == 0 || brightness == 255) {
fadeAmount = -fadeAmount ;
// wait for 30 milliseconds to see the dimming effect
delay(30);
//kucza
