Hello fellow tinkerers! I’m working on getting some RGB strips to fade in and out in sync with a color wipe pattern on the WS2812 NeoPixels. I’ve been screwing with this for about 2 days and and starting to get a bit frustrated.
The process needs to check the previous state of the RGB strip and compare it with the new state and decide whether to fade up, fade down, or do nothing for each individual color. For example, the red RGB would fade up with the red color wipe. For the purple wipe, the blue would fade in, but the red RGB, already lit, would remain lit instead of starting over at zero and fading in again.
With this latest attempt the wipes won’t go and there is no fading. I’v tried using less that/greater than operators, if/else statements and even tried using a switch case, but no go. Does anyone have any possible suggestions? I’m open to a whole new approach!
Thanks!
#define PINA 7 //ws2812 strip a
#define PINB 8 //ws2812 strip b
#define REDPIN 6 //RGB red
#define GREENPIN 5 //RGB green
#define BLUEPIN 3 //RGB blue
#define FADESPEED 5 // make this higher to slow down
#define NUMPIX 26 // number of pixels
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip_a = Adafruit_NeoPixel(NUMPIX, PINA, NEO_RGB + NEO_KHZ800);
Adafruit_NeoPixel strip_b = Adafruit_NeoPixel(NUMPIX, PINB, NEO_RGB + NEO_KHZ800);
int oldRed; //previous RGB red value
int oldGreen; //previous RGB green value
int oldBlue; //previous RGB blue value
pinMode(REDPIN, OUTPUT);
pinMode(GREENPIN, OUTPUT);
pinMode(BLUEPIN, OUTPUT);
strip_a.begin();
strip_a.show(); // Initialize all pixels to 'off'
strip_b.begin();
strip_b.show(); // Initialize all pixels to 'off'
analogWrite(BLUEPIN, 0); // Initialize RGB strip to 'off'
analogWrite(GREENPIN, 0);
analogWrite(REDPIN, 0);
oldRed = 0; //Set initial RGB values to 0
oldGreen = 0;
oldBlue = 0;
colorWipe(255,0,0); //wipe to red
delay(2500);
colorWipe(0,255,0); // wipe to green
delay(2500);
colorWipe(0,0,255); // wipe to blue
delay(2500);
colorWipe(255,255,255); // wipe to white
delay(2500);
colorWipe(0,0,0); // fade to black
delay(2500);
sparkle(1000);
void colorWipe(int r,int g, int b){
for(int x = 0; x < NUMPIX; x++){ //incriment counter
strip_a.setPixelColor(x, r,g,b); //turn on pixel
strip_b.setPixelColor(x, r,g,b);
Serial.println(x);
if (r==0 && oldRed==255){ // if new value is 0 and old value is 255
int newRed = 255-(x*(255/NUMPIX)); // fade out in as many increments as there are pixels
analogWrite(REDPIN,newRed);
if(x = NUMPIX){ // if all cycles are complete
oldRed = 0; //reset old value to 0
analogWrite(REDPIN, 0); //make sure lights are completly off
if(r==255 && oldRed==0){
int newRed = x*(255/NUMPIX);
analogWrite(REDPIN, newRed);
if(x = NUMPIX) {
oldRed = 255;
analogWrite(REDPIN, 255);
/* if (r > oldRed){ // new value greater than old (fade on)
int newRed = x*(; // add another incriment to new red value
oldRed=newRed; //reset old value to 255
if (r < oldRed); { // new value less than old (fade off)
int newRed=255-(x*10); // subtract another incriment from new red value
analogWrite(REDPIN, newRed); //fade red out
oldRed=newRed; //reset old value to 0
if (g >oldGreen){ // new value greater than old (fade on)
int newGreen = x*(255/NUMPIX); // add another incriment to new green value
analogWrite(GREENPIN,newGreen);
oldGreen=newGreen; //reset old value to 255
if (g < oldGreen);
int newGreen=255-(x*(255/NUMPIX)); // subtract another incriment from new Green value
analogWrite(GREENPIN, newGreen); //fade Green out
oldGreen=newGreen; //reset old value to 0
if (b > oldBlue){ // new value greater than old (fade on)
int newBlue = x*(255/NUMPIX); // add another incriment to new Blue value
analogWrite(BLUEPIN,newBlue);
oldBlue=newBlue; //reset old value to 255
else (b < oldBlue);
int newBlue=255-(x*(255/NUMPIX)); // subtract another incriment from new Blue value
analogWrite(BLUEPIN, newBlue); //fade Blue out
oldBlue=newBlue; //reset old value to 0
delay(100);
strip_a.show();
strip_b.show();
void sparkle(int d){
for(int x=0; d > x; x++){ //counter
int i;
int j;
int k;
i = random(150);
j = random(150);
k = random(150);
strip_a.setPixelColor(i, 175,255,0);
strip_a.setPixelColor(j, 255,255,255);
strip_a.setPixelColor(k, 175,175,255);
strip_b.setPixelColor(i, 175,255,0);
strip_b.setPixelColor(j, 255,255,255);
strip_b.setPixelColor(k, 175,175,255);
strip_a.show();
strip_b.show();
delay(30);
strip_a.setPixelColor(i, 0,0,85);
strip_a.setPixelColor(j, 0,0,85);
strip_a.setPixelColor(k, 0,0,85);
strip_b.setPixelColor(i, 0,0,85);
strip_b.setPixelColor(j, 0,0,85);
strip_b.setPixelColor(k, 0,0,85);
