Fade motor
Hi there,
i am new to arduino, never used something like that and i am not that good in electrical engineering but i want to learn about that with this device. i just bought a arduino uno and found this tutorial: http://arduino.cc/en/Tutorial/Fading
but how would i fade a motor like this with huge power drain? http://www.rcmodelle24.de/brushless-motoren/brushless-motor-1-10/lrp-vector-k4-brushless-motor-6-5-turn-typ-540er/a-188/
as i imagen the arduino will send a voltage from 0 to 5 V by analogWrite(0) to analogWrite(255). Am i right?
but what do i need if i like to use a motor with 7.4 V and up to 300 Watts?
thanks for help
greetings
If it is an RC motor, then an appropriate RC ESC can be driven using the servo library.
imagen about a motor like this
http://www.chinadcmotors.com/photo/pd25239-dc_electric_motor_rf_300_ca.jpg?iact=rc&dur=332&ei=TUWMToKsJYjzsgbO7sWMAg&page=1&tbnh=131&tbnw=188&start=0&ndsp=57&ved=1t:429,r:25,s:0&tx=143&ty=47
with only + and ground and huge power drain. how about this?
See reply #1
ok maybe i dont get it... my 2nd pictures does not show an RC motor and has only 2 wires. anyway i cannot find any ESC to buy. all my results end up like "you have to use a ESC" but where to get one?
From an RC store.
Some RC car motors are rated up to 20 or 30 amps at 7.2V, and they have only two wires.
If you just want simple speed control you can just wire the motor to a motor driver and apply PWM to it.
http://www.thebox.myzen.co.uk/Workshop/Motors_1.html
and
http://www.thebox.myzen.co.uk/Workshop/Motors_2.html
But the sorts of current you are taking about are quite high for home construction and way out of reach for a beginner.
As AWOL says you are much better off buying a motor controller.
If you're buying ESCs for motors be careful of the difference between the brushed (rare) and brushless (common) ESCs. A 2-wire DC motor requires a brushed ESC and a 3-wire DC motor needs a brushless ESC.
What's rare about a brushed motor RC ESC?
They been around for decades.
One obvios place to by an esc would be in the shop you mention http://www.rcmodelle24.de/
A cheaper alternative:
http://www.giantcod.co.uk/18-amp-esc-c-21_88.html
This is for bruchsless motors. The disadvantage of using one of these is that they only are able to make the motor go one way.
If you want 2 way action you should look at motors and ecs's for boats or cars.
There are to main categorys of brushless motors: sensorless (most common) and sensored (mainly car and boats) .
The sensored motors use small hall-effect sensors to "sence" the rotation of the motor, and these types needs special esc's that are able to read the sensors (they have more than 3 wires connected to the motor)
@AWOL
Brushed esc are rare because nobody use thém anymore, and that means it is hard (not imposible) to find a shop where you can buy one.
