Fade sequence not working
I have a project where I want 6 led's to fade in an out once triggered by and IR device. When I run the fading code by it's self all 6 led's behave as they should but once I introduce the IR code 2 out of the 6 lights will randomly blink and never fade like the others.
I've attached a video of this as well as the code, I'd appreciate any help....thank you!
Few will download the code as preferred method is to put it into the forum... I know file-sharing is efficient, but for now the forum spirit is to put it online here.
To assist, I have put it here.
#include <IRremote.hpp>
int IRpin=2;
IRrecv IR(IRpin);
decode_results cmd;
String myCom;
int ledPinYELLOW = 9;    // LED connected to digital pins
int ledPinGREEN = 10;
int ledPinORANGE = 6;
int ledPinRED = 5;
int ledPinBLUE = 3;
int ledPinWHITE = 11;
int ms=5;
IR.enableIRIn();
  while (IR.decode(&cmd)==0){
delay(1500);
IR.resume();
if (cmd.value==0xFF6897){
  myCom="zero";
  Serial.println(myCom);
if (cmd.value==0xFF30CF){
  myCom="one";
if (cmd.value==0xFF18E7){
  myCom="two";
if (cmd.value==0xFF7A85){
  myCom="three";
if (cmd.value==0xFF10EF){
  myCom="four";
if (cmd.value==0xFF38C7){
  myCom="five";
if (cmd.value==0xFF5AA5){
  myCom="six";
if (cmd.value==0xFF42BD){
  myCom="seven";
if (cmd.value==0xFF4AB5){
  myCom="eight";
if (cmd.value==0xFF52AD){
  myCom="nine";
if (cmd.value==0xFFA25D){
  myCom="pwr";
if (cmd.value==0xFF629D){
  myCom="v+";
if (cmd.value==0xFFE21D){
  myCom="fun";
if (cmd.value==0xFF22DD){
  myCom="rew";
if (cmd.value==0xFF02FD){
  myCom="play";
if (cmd.value==0xFFC23D){
  myCom="ff";
if (cmd.value==0xFFE01F){
  myCom="dn";
if (cmd.value==0xFFA857){
  myCom="v-";
if (cmd.value==0xFF906F){
  myCom="up";
if (cmd.value==0xFF9867){
  myCom="eq";
if (cmd.value==0xFFB04F
  myCom="st";
if (myCom=="one")
// Sequence 1
  // fade in from min to max in increments of 5 points:
  for (int fadeValue = 0 ; fadeValue <= 255; fadeValue += 5) {
    // sets the value (range from 0 to 255):
    analogWrite(ledPinYELLOW, fadeValue);
    // wait for ms milliseconds to see the dimming effect
    delay(ms);
  // fade out from max to min in increments of 5 points:
  for (int fadeValue = 255 ; fadeValue >= 0; fadeValue -= 5) {
    delay(ms);
    analogWrite(ledPinGREEN, fadeValue);
    delay(ms);
    delay(ms);
    analogWrite(ledPinORANGE, fadeValue);
    delay(ms);
    delay(ms);
    analogWrite(ledPinRED, fadeValue);
    delay(ms);
    delay(ms);
    analogWrite(ledPinBLUE, fadeValue);
    delay(ms);
    delay(ms);
    analogWrite(ledPinWHITE, fadeValue);
    delay(ms);
    delay(ms);
The code as posted compiles, BUT around line #116 you have:
 if (myCom == "one")
    // Sequence 1
I suspect you need a "{" and a matching "}" to indicate a block of logic.
You should also study:
switch...case - Arduino Reference
The IRremote library uses Timer1 so you can't use hardware PWM (analogWrite()) on pins 9 and 10 when you use IRremote.
johnwasser, the lights that are having the problem are on pin's 11 & 3, pins 9 & 10 work fine.
Thank you mrburnette, this is my first post I wasn't sure which way to post the code.
I tried adding {} before and after the if statement but I get an error saying "expected primary-expression before'}' token."
Maybe they changed the default timer. Same effect, different pins.
I'm using an Uno would a different board work?
Yes. An Arduino MEGA 2560 has more timers and many more PWM pins.
